Spencer Cycle exhaust bracket installed... pics> - Kawasaki ZX-10R.net
post #1 of 27 Old 12-17-2004, 04:12 PM Thread Starter
Post Whore
El Diablo's Avatar
I ended up orderin' a Spencer Cycle black anodized exhaust bracket this week. It came in today so I stuck it on. Gotta say that this is a nice quality piece. Install was simple enough, too. A 6mm allen wrench/socket for the two bracket attachment bolts, and two wrenches (10mm & 12mm) for the muffler strap bolt & nut are the only tools ya need to make the swap. The Spencer bracket uses the same muffler attachment point and angle that the stock bracket does so the bracket is a direct replacement for the passenger peg brackets with stock exhaust as well as any other system that will work with the stock bracket.
Here's a "before" shot...
The Spencer bracket also uses the factory rubber grommet for the muffler strap bolt. Simply pry the two metal inserts out and work the grommet out by pinchin' it together on one end and wigglin' it through. Here's a pic of all three parts out of the bracket. I got a little blur from hand movement in this shot but you can still see the pieces...
And here's the "after" shot. The rubber grommet is squeezed and wiggled through the Spencer bracket and the metal inserts are pushed in from each side. Then it's simply a matter of puttin' the bracket bolts in and hangin' the can onto the new bracket...
And a side by side of the before and after shots...
I love the cleaner, blacked out look. I' gonna send the passenger brackets/pegs to be powdercoated black. That way I don't have to give up the clean look if I put 'em on in the event that I wanna go two up. I don't think that's gonna be a problem though. Can't seem to find many girls around here that are willin' to climb onto a crotch rocket.
El Diablo is offline
post #2 of 27 Old 12-17-2004, 04:33 PM
Big Daddy's Avatar
Images: 38
smooooooth
Big Daddy is offline
post #3 of 27 Old 12-17-2004, 04:53 PM Thread Starter
Post Whore
El Diablo's Avatar
Originally Posted by Big Daddy
smooooooth
Yeah, thanks for the heads up on this piece. Couldn't find exactly what I wanted until I saw yours. Prolly would have bought a Muzzy's if I hadn't seen the Spencer piece.
post #4 of 27 Old 12-17-2004, 05:47 PM
MIA Post Whore
miykl's Avatar
I found changing the rubber grommet to be a PIA. If you're lazy like me and will be swapping back and forth farely often between the stock rear pegs and the hanger, buy a second grommet and the steel insert thingies from your dealer. BTW- good write up as usual EL D.
miykl is offline
post #5 of 27 Old 12-17-2004, 06:02 PM Thread Starter
Post Whore
El Diablo's Avatar
Yeah, it can sort of be a beeyotch gettin' the grommet out and back in, especially when it's cold. Not a bad idea gettin' an extra for swappin' back and forth either. Hadn't thought of that but it would definitely save time and hassle if you swap much at all. Thanks for the tip... and the compliments on the write up.
post #6 of 27 Old 12-17-2004, 06:22 PM
Andy's Avatar
Images: 25
Damn purty!
Andy is offline
post #7 of 27 Old 12-17-2004, 07:24 PM Thread Starter
Post Whore
El Diablo's Avatar
Originally Posted by Andy
Damn purty!
Ain't it though? Thanks, man. I'll get some full side shots tomorrow.
post #8 of 27 Old 12-17-2004, 10:49 PM
Thats nice! How much?
zx102nv is offline
post #9 of 27 Old 12-17-2004, 11:41 PM Thread Starter
Post Whore
El Diablo's Avatar
$89.99 and shipping at THIS LINK.
post #10 of 27 Old 12-17-2004, 11:44 PM
Thanks!
zx102nv is offline
Let's See That Performance Wish List......... SP8 The ZX-10R 22 05-29-2004 08:27 AM
