Speedometer not working. - Kawasaki ZX-10R.net
post #1 of 14 Old 03-26-2009, 09:10 PM Thread Starter
caboose's Avatar
Send a message via MSN to caboose
Bike is an 04. Had it apart this winter and just got it pretty much put back together and i noticed today that the speedometer stays at 0.
Sprocket cover and sensor appear to be installed correctly. I know there's one connector at the bottom of the motor and another behind the top, right motor mount. I still have to make sure those connections are good.
Are the CSS sensors prone to failure? is it likely just a bad connection somewhere? Any one else had this start happening for no apparent reason?
caboose is offline
post #2 of 14 Old 03-26-2009, 09:19 PM
bluedevil's Avatar
Not common...04 bike is easy to check out. Do you have a SpeedoHealer?....If not shame on you as that also makes it easy to test out your system.....but yes check out the connector by the motor if not.
bluedevil is offline
post #3 of 14 Old 03-26-2009, 09:22 PM Thread Starter
caboose's Avatar
No speedohealer. So far couldn't be bothered to install one, the speed being off doesn't really bother me.
Alright, i'll get me some dielectric grease and do some wire wiggling.
caboose is offline
post #4 of 14 Old 03-27-2009, 05:43 PM
Supercharged Mod
It's really easy to pinch the wire that goes down from the upper fairing, along the left side of the engine, to the plug for the speed sensor. Been there ...
GoFaster is offline
post #5 of 14 Old 03-28-2009, 01:23 PM
nnorz's Avatar
hi there....,mi speedo is working but the numbers keep jumping up n down..
wat the cause of these.bad speedo sensor or i need to clean up n check wiring...
nnorz is offline
post #6 of 14 Old 03-28-2009, 01:37 PM
luxurylows's Avatar
SPEED SENSOR may be the cause.. I have a NEW OEM speedo sensor CHEEP.. I bought it for my 05 and came to findout it was the METER itself.. LMK if anyone needs one..
luxurylows is offline
post #7 of 14 Old 03-28-2009, 03:34 PM Thread Starter
caboose's Avatar
well i pulled all the connectors, put some dielectric grease on them then put em back together. after i cleaned the two connectors behind the left upper the speedo worked again. after i put all the fairings back on it wasnt working.
seems like a bad connection somewhere, gonna take em back off again soon and make sure nothing is pinched.
caboose is offline
post #8 of 14 Old 03-28-2009, 03:49 PM
bluedevil's Avatar
Did you check the Instrument Cluster Connector as well? Also try pulling out the Speed sensor it's easy to do and clean it. You can also check voltages at the bottom of the engine connector because the Cluster for the 04/05 is supplied by the cluster to the Sensor. This is another reason besides the Speed being off by 6% on your bike to have a SpeedoHealer. It has a test mode to simulate the Speed sensor and helps in troubleshooting problems like this. Good luck and let us know.
bloo
post #9 of 14 Old 04-04-2009, 09:51 PM Thread Starter
caboose's Avatar
turns out it was the plug on the back of the instrument panel. wasn't quite clicked in completely, shoved it in there properly with some dielectric grease and it seems to be working properly. i don't even remember unplugging that connector! oh well.. the winters rebuild is now 100% complete!
caboose is offline
post #10 of 14 Old 04-05-2009, 02:26 AM
jdgun_13's Avatar
Send a message via Yahoo to jdgun_13
Well how about some pics Caboose?
jdgun_13 is offline
06 zx10r speedometer upon1zx10r Parts, Gear and Accessories 8 03-14-2011 11:32 PM
Speedometer not working tander2114 The Out House 6 08-27-2010 11:48 AM
08 speedometer on the 06/07? Ibzx10r Performance and Tech 7 02-04-2008 11:14 AM
WTB 04-05 speedometer(tach) swing lo Wanted: Buy or Trade 2 12-02-2007 06:04 PM
wtb 04-05 speedometer mikebar4 Wanted: Buy or Trade 0 10-16-2006 05:15 PM
