speedohealer settings?????? - Kawasaki ZX-10R.net
post #1 of 24 Old 02-06-2005, 12:56 AM Thread Starter
Can someone give me the settings for my speedohealer??? I want the speedo as close to actual as possible...
I need the settings for each of these:
16/39
17/39(stock)
16/41
17/41
18/41
18/44
Thanks
Russ
[email protected]
on1whl is offline
post #2 of 24 Old 02-06-2005, 02:41 AM
OG Post Whore
stunnerific_harry's Avatar
Send a message via AIM to stunnerific_harry
i need to find my speedo healer
stunnerific_harry is offline
post #3 of 24 Old 02-06-2005, 05:57 AM
Big Daddy's Avatar
Images: 38
Russ
17/39 stock is 6%
16/39 is 12%
Big Daddy is offline
post #4 of 24 Old 02-06-2005, 07:46 PM
It depends on your rear tire, but based on the stock setup reading 6% high:
16/39 13%
17/39 6%
16/41 18%
17/41 11%
18/41 5%
18/44 13%
Cryptoman is offline
post #5 of 24 Old 02-06-2005, 07:57 PM
bluedevil's Avatar
16/39 13%
17/39 6%
16/41 18%
17/41 11%
18/41 5%
18/44 13%
I think 18% is fairly high for the 16/41 which I have. I have not completly tested at higher speeds but I do have a radar gun and at -11.1% at 50mph it was only 1mph off. If the speedhealer can't correct after going another 100mph or so and be within at least 5mph after the 50mph tests than I think it is no better than the stock sensor for top speed results.
bluedevil is offline
post #6 of 24 Old 02-06-2005, 08:03 PM
bluedevil's Avatar
Sorry, let me correct myself. I have a 16/40 at -11.1%, but I still think your numbers will come up higher than mine with a radar gun. I think part of the problem is there is no definite error for the stock Speedo which is assumed to be 5% or higher, but obviously there must be variances among the stock gauges.
post #7 of 24 Old 02-07-2005, 09:43 AM
go to calisportbike and they have a calculator that will give you that info
MAVRIK is offline
post #8 of 24 Old 02-10-2005, 04:27 AM
Slight off shoot, has anyone looked at the gearing calculators that have been posted here?
Im wondering if one could go by what the speed is given in those calculations, ie in 3rd gear at 3000rpm your speed should be 32mph, 4000rpm 42.7mph, seeing that wind at these speeds is not much of a factor would it seem reasonable to go by these speeds for correcting the speedohealer?
Ive previously set mine at 12.7%, but now im wondering, seems to be a difference of 9.8% between what mine and the gearing calculator reads, mine reads lower.
sp500 is offline
post #9 of 24 Old 02-10-2005, 08:24 AM
if you going for exact mph then going -1 in front the correction would be about 10.8%, if you want to leave the error speedo buffer that comes from the factory then it is about 6%
MAVRIK is offline
post #10 of 24 Old 02-10-2005, 08:38 AM
Cheers, it seems my assumption was correct.
Was probably blatantly obvious but wanted to check.
sp500 is offline
SpeedoHealer Install step by step w/pics>> El Diablo Performance and Tech 80 04-24-2008 12:53 PM
Winterizing & the Speedohealer? RichTJ99 The ZX-10R 7 12-03-2004 04:02 PM
SpeedoHealer price? El Diablo Vendors deals 16 11-22-2004 01:26 PM
SpeedoHealer Pics & Basic Instructions Xusia Performance and Tech 39 08-01-2004 08:03 PM
Suspension Settings a The ZX-10R 2 04-06-2004 12:20 PM
