Speedohealer ? - Kawasaki ZX-10R.net
post #1 of 15 Old 07-16-2005, 09:37 AM Thread Starter
O10R's Avatar
Speedohealer ?
I got in on the group buy from Brad and I didnt get the extended cable, I was wondering if it is possible to get just the longer harness.
O10R is offline
post #2 of 15 Old 07-16-2005, 11:14 AM
Post Whore
El Diablo's Avatar
I'm sure you can order the longer harness separate. Just contact some site sponsors and see if they can hook you up.
"Bottom line, when I'm on that bike, it's just me and God...And He better be holding on."- Stillie on SSB
Si vis pacem, para bellum...
El Diablo
El Diablo is offline
post #3 of 15 Old 07-16-2005, 12:39 PM
IF your talking the ext cable, the boxes are different, the ext has no button only a plug in, so the extension is your button. The one without the extender has a button on the face of the box, but no place to plug in the extender
vegasdude is offline
post #4 of 15 Old 07-16-2005, 12:59 PM
Post Whore
El Diablo's Avatar
I stand corrected...
El Diablo
post #5 of 15 Old 07-16-2005, 03:43 PM
The reason, I know is when I got mine, it kept saying push the button and I could find no friggin button.............so I plugged the extension and pushed that button and it worked..................the instructions aren't different between the two models..............
post #6 of 15 Old 07-16-2005, 04:15 PM
Images: 59
Man I could sure use a Speedohealer. How about it Rich? Speedohealer giveaway for August?? COME ON!!!!
bchild is offline
post #7 of 15 Old 07-16-2005, 09:50 PM
I was looking for the button too.... After the trouble of finding a place to mount the remote recall button I'm thinking that the standard SH may have been cleaner. The only real benefit I see is that you can mount the box out of sight and the recall is easier, but I spent a good hour running the ext cable to get it totally out of sight.
king-tony is offline
post #8 of 15 Old 07-17-2005, 02:23 AM
Post Whore
El Diablo's Avatar
Moved to tech...
El Diablo
post #9 of 15 Old 07-17-2005, 02:33 AM
your better off with ext, cause if you have to change your settings you don't need to pull your seat; just clear the memory with the ext button then put your correct inputs in and then go test. Much easier to program in the long run.................
post #10 of 15 Old 07-17-2005, 12:37 PM
How do you program without removing the seat? I thought you had to move one of the 6 dip switches depending on what you are programming.
Speedohealer install problem king-tony Performance and Tech 2 07-12-2005 08:42 PM
Speedohealer vegasdude Performance and Tech 4 06-11-2005 03:21 PM
speedohealer Stud_wit_style The ZX-10R 9 05-01-2005 05:20 AM
Winterizing & the Speedohealer? RichTJ99 The ZX-10R 7 12-03-2004 04:02 PM
SpeedoHealer Pics & Basic Instructions Xusia Performance and Tech 39 08-01-2004 08:03 PM
