Speedo help - Kawasaki ZX-10R.net
post #1 of 5 Old 06-11-2007, 12:13 PM Thread Starter
BRI10R's Avatar
Question Speedo help
Hi
I am having a problem with my speedo/odom -- neither is working. The tach and all indicator lights are fine. I recently replaced fork seals and also did an oil change but I don't think either of those would have done this. Has anyone else had this problem or know what to check??
Thanks in advance
BRI10R is offline
post #2 of 5 Old 06-11-2007, 12:43 PM
kawaking's Avatar
Send a message via AIM to kawaking
please be specific on how it is not working. I had issues with my 2000 r6 tach not working. It ended up being wireing problems. somehow some of the wires out of the tach had pulled out. there pretty cheap so i just bought a new tach. But you know if the needle doesnt work it can only be 2 things, a bad connection on a wire, or you need a new tach because its just faulty. it happens.
06 Lime 10R, street bike
00 Black R6, track bike
kawaking is offline
post #3 of 5 Old 06-11-2007, 01:00 PM
FAF
Rent this space
Check your speed sensor down by the front sprocket, it may be loose or disconnected.
FAF is offline
post #4 of 5 Old 06-11-2007, 01:04 PM Thread Starter
BRI10R's Avatar
not reading any MPH and miles are not registering, but the rpm's are working.
BRI10R is offline
post #5 of 5 Old 06-11-2007, 01:52 PM
FAF
Rent this space
It will be the sensor, or its connectors.
FAF is offline
04-05, 06-07 speedo zx10r85 The ZX-10R 2 04-26-2007 07:30 PM
Need Speedo Help Bad spawny The ZX-10R 2 07-04-2006 08:59 PM
05 vs 06 Speedo crootster10R Performance and Tech 1 06-16-2006 08:22 AM
Speedo yamadak13 The ZX-10R 8 06-10-2006 12:07 PM
will 06 Speedo fit 05 10r Jamie26 The ZX-10R 17 05-29-2006 10:34 PM
