Speed sensor problem - Kawasaki ZX-10R.net
post #1 of 2 Old 05-30-2015, 01:16 PM Thread Starter
kenny plyer's Avatar
I have just picked my 05 ZX10 up from having a ful service and a Dyno run with set up at my nearest main dealer and on the ride home I noticed that no speed was registering on the speedo and the FI light was on. So I phoned the dealer when I got home to ask if it was possible that something was left a drift after the dyno run. They said probably not but I should check the speed sensor on the side of the front sprocket cover and make sure the block connector was together. Which I did and it was so I asked them to order me a new speed sensor. Then I thought I would have a look on line at the problem and on an old post on ZX10.net I found someone had something similar and that turned out to be a crimped wire behind the engine bracket after having the sparkplugs changed. So I took the left hand side fairing off only to find the speed sensor cable squashed behind the engine bracket. So it's got to go back. I normally do my own servicing and I think I will start doing it again.
kenny plyer is offline
post #2 of 2 Old 05-30-2015, 01:18 PM
SkyDork's Avatar
It's not an F1 light.
https://www.zx-10r.net/forum/f28/all-.../topics/218666
#WordCrimes
SkyDork is offline
Gen 2: speed sensor duggan98tj The ZX-10R 1 07-30-2013 09:26 PM
Gen 2: speed sensor Sharkysreef General Motorcycle Discussions 5 02-03-2013 12:54 AM
Speed Sensor???? BornSinner Performance and Tech 2 03-19-2009 12:47 AM
Speed Sensor 10R Performance and Tech 14 08-24-2008 12:36 AM
where is the speed sensor? pikaso The ZX-10R 6 09-11-2007 09:27 PM
