Speed Sensor???? - Kawasaki ZX-10R.net
post #1 of 3 Old 03-18-2009, 07:47 PM Thread Starter
BornSinner's Avatar
Images: 19
Send a message via AIM to BornSinner
Speed Sensor????
Im getting a code for the Speed Sensor.....
What for I need to do to fix this????
BornSinner is offline
post #2 of 3 Old 03-18-2009, 08:15 PM
Supercharged Mod
Q: does your speedometer work?
You have a problem with the VSS (vehicle speed sensor) which is on the countershaft sprocket cover, or the wiring to that sensor.
GoFaster is offline
post #3 of 3 Old 03-19-2009, 12:47 AM
bluedevil's Avatar
Well not only does that question need to be answered but others like do you have a Speedohealer.
Also there is a connector on the left side of the around the engine before the signal goes up to the Instrument Cluster that should and does get alot of debris. I would check that connector out first like unplug it(it has 3 wire connections to each plug) and then clean plus put some dielectric cream inside as well to help corrosion and conductivity. ....but yes need more Info f'sho.
bloo
bluedevil is offline
Speed Sensor 10R Performance and Tech 14 08-24-2008 12:36 AM
where is the speed sensor? pikaso The ZX-10R 6 09-11-2007 09:27 PM
Speed Sensor Need Info. bluedevil Performance and Tech 0 10-11-2006 05:05 PM
10R Speed sensor connector location Vince10R Performance and Tech 6 02-13-2006 06:31 PM
