spark plugs - Kawasaki ZX-10R.net
post #1 of 10 Old 08-18-2012, 02:56 PM Thread Starter
skee05's Avatar
spark plugs
Will it be okay if I used cr9ek spark plugs in my 05 10 I brought them for my twelve before I sold it
skee05 is offline
post #2 of 10 Old 08-18-2012, 03:28 PM
All show and all go 10r
JLG0987's Avatar
they should fit they have a smaller gap 12R .032 vs 10R .036. Not sure if or how that would affect performance but they should fit. Really that aren't that expensive and you don't have to change them that often just get the proper ones. You might be able to exchange them if they're new.
JLG0987 is offline
post #3 of 10 Old 08-18-2012, 03:58 PM
Post Whore
-Op-'s Avatar
This is probably true actually. Would be worth giving it a shot. to JLG though, Id just get the ones that are supposed to go into it.
-Op- is offline
post #4 of 10 Old 08-18-2012, 04:02 PM
JLG0987's Avatar
sorry I'm on crack I don't know where I came up with the 12R. the cr9ek is multi vs single tip as far as I know. The gap is now quite a bit smaller at .028. I wouldn't use them. They would still probably fit though as the profile would most likely be quite shorter.
JLG0987 is offline
post #5 of 10 Old 08-18-2012, 05:23 PM
bluedevil's Avatar
Just putting the Information out there you can make up your own mind:
https://www.zx-10r.net/forum/showthread.php?t=9400
bloo
____________________________________________
Sent from My Computer via DSL mid to low service Firefox updated version, sometimes wireless sometimes Wire from the garage depending on connection speed.
bluedevil is offline
post #6 of 10 Old 08-18-2012, 06:39 PM
zx racer's Avatar
i would just stick with the oem plug NGKCR9EI its only couple of bucks more but last alot longer... you can get them at advance auto part stores around 5 bucks a plug.
05 ZX-10R SWB.
zx racer is offline
post #7 of 10 Old 08-18-2012, 07:39 PM
Shift_Nashville's Avatar
Don't do it...your bike came with your specific size for a reason...exchange em, or wait till you can buy the correct size...or you can just do it, and let us all know how it works out for you...
i could give two shits if you were taking a bubble bath in applesauce being fed grapes by lemurs with electrodes attached to your nipples in the bed of a semi truck, as long as you're not holding up traffic, go for it
Shift_Nashville is offline
post #8 of 10 Old 08-19-2012, 02:30 AM Thread Starter
skee05's Avatar
plugs
Just gonna get the proper ones this week because putting them in looks to be a hellva job! Thanks fellas
skee05 is offline
post #9 of 10 Old 08-19-2012, 02:33 AM
ZX-10R enthusiast
dudewhrsmybike's Avatar
Yea, having to take the frame mounts out sucks. You have to get the right tool combination going to easily remove/install the frame mounts and plugs...GL
Strictly for my Ninjas
https://www.instagram.com/mistr.123/
Current Ride: 2016 ZX-10R ABS (under construction)
Former Ride: 2011 ZX-10R ABS
17/41, Woolich Racing Tuned ECU and QS, Rifleman's 1/5th throttle insert, CL XBK5 pads, Yosh case sliders, Mivv Carbon w/ Ti Akra link
dudewhrsmybike is offline
post #10 of 10 Old 08-19-2012, 03:48 AM
thundercoupe9's Avatar
I am running cr9ek plugs and loving them, you just have to pull them out once a year and clean the threads that is in the combustion chamber, that's about it.
thundercoupe9 is offline
spark plugs jsemm The ZX-10R 14 11-30-2011 06:14 PM
spark plugs slav Performance and Tech 12 10-28-2008 02:01 PM
Spark plugs OneSLOW10 General Motorcycle Discussions 4 04-13-2008 04:37 PM
Ahh the joy of doing spark plugs TI10 Performance and Tech 15 06-25-2007 11:46 PM
spark plugs eric The ZX-10R 11 04-18-2006 11:17 PM
