Spark or Fuel - Kawasaki ZX-10R.net
post #1 of 4 Old 03-31-2019, 04:12 PM Thread Starter
zx racer's Avatar
Spark or Fuel
Hey guys here recently my 05 zx10 has been idleing rough sounds like its miss firing. So i decided to check each header tube right to left standing in front of the bike. After leting the bike warm up for 30sec here is what i got below which is weird. I wouldve thought the temps read closer to each or is this normal? I havent check the fuel pump but it primes like it should and pulls good threw the gears to rev limiter.
Cyl#1 - 178.3
Cyl#2 - 176.0
Cyl#3 - 194.0
Cyl#4 - 217.2
Any advice on what it could be will be appreciated.
Sent from my SCH-I545 using Tapatalk
05 ZX-10R SWB.
zx racer is offline
post #2 of 4 Old 03-31-2019, 07:19 PM
gaz
check throttle sync, ck cranking compression, adj valves as needed, get injectors cleaned/flowed. restore idle balance/power.
gaz is offline
post #3 of 4 Old 03-31-2019, 07:50 PM Thread Starter
zx racer's Avatar
Just check the valves and sync the tb's so doubt thats it. Did some more checking and found cyl #1 feels colder than the rest. Would that cause idle to be rough?
05 ZX-10R SWB.
zx racer is offline
post #4 of 4 Old 04-01-2019, 05:45 AM
gaz
injectors
gaz is offline
Gen 1: no spark or fuel kawasaki210 The ZX-10R 2 06-02-2016 03:33 PM
Gen 4: Fuel Tank - Metallic Spark Black - Brand New ITB CanyonCarver Parts, Gear and Accessories 9 03-23-2016 10:54 AM
Please Help!!! 2006 ZX10r NO FUEL NO SPARK DJCK22 The ZX-10R 4 07-26-2010 10:30 PM
Rev limiter cuts fuel or spark? Both? dsabat Performance and Tech 19 06-29-2007 09:05 AM
WTB Fuel tank/Fuel pump bellevuetlr Wanted: Buy or Trade 2 12-13-2005 07:43 AM
