Some mods, and weights.... - Kawasaki ZX-10R.net
post #1 of 33 Old 03-20-2010, 05:11 AM Thread Starter
DEATH_INC.'s Avatar
Put some new bits and pieces on the green beast today, took down some weights for those interested.....
520 chain and sprocket kit, sprockets only; supersprox rear, can't remember the brand of the front 16/40 @ .88kg, stock front/rear @ 1.01kg
Chain EK mxvz (i think) 520 pitch @ 2.03kg and stock at 2.05kg (I found that interesting)
Carbon front gaurd (osk bodykit) .55kg and stock @ .62kg
Carbon rear hugger and chaingaurd (same brand) @ .36kg and stock at .36 too
Replaced the bolts to hold these on at the same time with pro-bolt ones, .015kg and stock @ .04kg.
And a keyless filler cap, gas-cap-dude (e-bay) @ .15kg, down from .52kg stock.....
Soooo, no real difference in the chain, despite being a 520 over the stock 525 (gearing change should be good though), bugger all in the carbon stuff, the best loss was in the cheapest part.....
Total for the stock stuff was 4.6kg, and the new stuff 3.985kg, for a total loss of .615kg....
Haven't re-weighed my credit card yet, it's a fair bit lighter though
DEATH_INC. is offline
post #2 of 33 Old 03-20-2010, 07:51 AM
MIA Post Whore
miykl's Avatar
curious about the chain....was that after cutting it to length?
miykl is offline
post #3 of 33 Old 03-20-2010, 01:22 PM
RPG76's Avatar
Well I guess it just shows how hard it is to get real unsprung weight savings....
Anyway, I too got a Supersprox and Ek mvxz 520 setup waiting to go on. After having looked at it and held it, I firmly believe that the Supersprox are pure snake oil. You "might" get some savings on a 530 setup but I do not think for one second that you save any weight over a well made all steel sprocket in 520. Also think it looks a bit cheesy (rivets look cheap) but that's an opinion.
I also bought a set of aluminum lug nuts at the same time and they don't seem to have any weight so might make up for the extra teeth on the supersprox
I have to say that the best bang for the buck weight savings I have seen yet is the MDA123 battery pack!!!
RPG76 is offline
post #4 of 33 Old 03-20-2010, 02:04 PM Thread Starter
DEATH_INC.'s Avatar
Yep. Before it was 2.2kg. I nearly put it all in the skip....
Total savings on the chain/sprocket was only 150 grams (5.29oz), and I'd say most of that was in the ally bit of the supersprox, which is towards the centre of the sprocket, where it will do the least good for rotational mass. Still helps a little with unsprung weight, but I reckon you'd get better results looking at tire weights...
post #5 of 33 Old 03-20-2010, 02:05 PM Thread Starter
DEATH_INC.'s Avatar
Yeh, I went to the local supplier to get some ti ones, but he didn't have any in stock (or ally), any idea of the weight diff?
What's the go with the battery? How much did that shave off?
post #6 of 33 Old 03-20-2010, 02:31 PM
RPG76's Avatar
Wishful thinking on my part most likely lol. Have not pulled the stock ones off yet but even then I don't think it will be that much, maybe 30-50% less than stock (about what I saved over the stock caliper bolts going to Ti).
If you have a look on some of the the other threads on this, it saves a measurable 7 pounds over the stock batt.
RPG76 is offline
post #7 of 33 Old 03-20-2010, 02:44 PM Thread Starter
DEATH_INC.'s Avatar
Yep, found it. Cheers.
post #8 of 33 Old 03-21-2010, 10:54 PM Thread Starter
DEATH_INC.'s Avatar
Ordered one :)
Here's a pic of the new bits... (I'll add a pic of the whole thing when I get it out next.)
I also added 5mm to the rear ride height spacer to lift the rear a bit.
And a green screen
post #9 of 33 Old 03-21-2010, 11:01 PM
flthy1's Avatar
Nice add ons! Shirvin would be interested in these weight savings
flthy1 is offline
post #10 of 33 Old 03-21-2010, 11:07 PM
FEELING LUCKY, PUNK ?
Lucky10R's Avatar
Images: 19
nope.. he'd be all over the neon screen
Lucky10R is offline
04 zx-10r rim weights homeguard The ZX-10R 4 10-04-2006 09:23 AM
3/4 lb bar end weights joedirt199 The ZX-10R 11 06-07-2006 05:54 AM
tire weights CBRE Performance and Tech 2 05-30-2006 06:01 PM
flywheel weights BNninja Performance and Tech 4 03-17-2005 10:55 PM
Springs: For the heavy weights! Vonstallin The ZX-10R 39 01-07-2005 11:58 AM
