Some good info - Kawasaki ZX-10R.net
post #1 of 3 Old 12-12-2005, 04:00 PM Thread Starter
Post Whore
1killer1liter's Avatar
Images: 11
Some good info
Jeremy,
To be honest with you the couple of ZX10ís that we have tested here did not gain anything by mapping the ignition curve. If you are just concerned with pulling out timing for use with Nitrous then I would either get with an engine builder or someone familiar with Nitrous to give you a suggestion as to how far to go. Most guys just start pulling out 5-8 degrees just to be on the safe side. We are working on a hub that will work with the PCIII USB that will give you the ability to hold two maps and also run a nitrous solenoid. When the solenoid is activated it will automatically switch to the other map (if you want it to) which can be setup for the nitrous. This works real well for the guys with dry nitrous.
Technically we are not open to the public for mapping but I do quite a bit of work after hours. If you are interested let me know, I charge $200. Thanks.
Dustin Schaller
Powersports Technical Support Manager
Dynojet Research
800-992-4993
www.dynojet.com
www.powercommander.com
I live my life a quarter-pounder at a time. And for those 500 calories or more, im free. I need FRIESSSS! Two of them. The big ones. Oh, and I need them tonight. You're lucky the double shot of BBQ sauce didnt blow a seam on your nugget box.
1killer1liter is offline
post #2 of 3 Old 12-12-2005, 04:13 PM
Big Daddy's Avatar
Images: 38
he's based in Vegas isn't he?? thats where i would have gone if it weren't for Folsom Kawi.
Big Daddy is offline
post #3 of 3 Old 12-12-2005, 04:33 PM
sneaky's Avatar
I have a couple of friends that were in vegas for a R1 convention and stopped by dynojet and ended up getting some free custom maps for their PCIII.
Thay had nothing but great things to say about dynojet.
sneaky is offline
bad custom map vs. good custom map DB The Out House 5 11-04-2005 07:32 AM
Road racing World magazine tire test... vizsladog Performance and Tech 27 10-15-2005 11:12 AM
Hurts so good miykl The Out House 10 10-10-2005 02:34 PM
Parting out a perfectly good bike? El Diablo The Out House 6 09-21-2005 02:43 PM
PcIIIusb...install Info. R1GSXRKILLER The ZX-10R 23 02-11-2005 10:41 PM
