Soft Brakes - Kawasaki ZX-10R.net
post #1 of 23 Old 08-11-2007, 06:11 PM Thread Starter
Kwaky's Avatar
Soft Brakes
Ok so when I first got the 10 2 years ago brakes were fabulous. I put a pair of HH pads on them for some reason when I put the pads on they somehow scared the freaking rotor? wtf...Anyways got the rotors worked a little but bottom line is I want a little more braking power. My thoughts are.
Find ZX 14 Calipers. Alone this appears to be a fix all for our brakes even though I still think they are reasonable brakes to begin with but. Better is still better.
Steel lines. Ok so new pads and steel lines what change will this make?
Brembo Master Cylinder and New lines. With the factory calipers what kind of difference can i expect here. I don't want stupid levels of sensitivity but I definetly don't like feeling like I have to squeeze the breaks to bring it down from speed when I have to hit the brakes hard.
0510R PCIII dyno tuned 520 X -1+2 sprockets. slip on and a few other Knick Knacks filter plugs emissions dyno tune. And 20,000 miles of learning on this one anyways.
Kwaky is offline
post #2 of 23 Old 08-11-2007, 06:21 PM
WOODYZX10R's Avatar
i would do 1 lines, 2 brembo master and calipers last if you dont like what you have. i have stock calipers with 20mm oversize rotors, hh pads, and the stock master with speigler lines and my brakes are awesome. i have a brembo master that i will be putting on soon when i have time.
2004 ZX10R, mostly kinda stock
WOODYZX10R is offline
post #3 of 23 Old 08-11-2007, 07:08 PM
rocketracermike's Avatar
I have brembo, steel lines, HH pads and zx14 calipers. have no problem stopping.
rocketracermike is offline
post #4 of 23 Old 08-11-2007, 07:58 PM
mach_man_187's Avatar
bend your stock brake lever away from the bar just a hair.....
If you're not living on the edge, your taking up too much space!
mach_man_187 is offline
post #5 of 23 Old 08-12-2007, 03:13 PM
norcal10's Avatar
i bolted on a complete 05 636 front brake system (master, lines, calipers, pads) and the brakes are 100x better than before. i have ebc hh pads and new lines for it, i imagine it will only help even more. also, i ran dot5 fluid, and got no fade at the last track day. i bought the entire brake system on ebay for about $125 shipped. compared ot the cost of the brembo mc alone, it is a pretty good deal.
norcal10 is offline
post #6 of 23 Old 08-12-2007, 03:23 PM
Ninja187's Avatar
I use my feet like Fred Flintstone to stop.
GEN 4: Brembo HP calipers, Brembo HP T-Drive Rotors, Brembo RCS master cylinder, Fren Tubo SS lines, re-valved Ohlins damper, Ohlins TTX shock, Yoshimura case covers/frame sliders, Yoshimura 3/4 R77D Ti exhaust, BMC filter, Puig DB, Renthal Clip ons/sprockets, attack rearsets, Guhl flash, kawi kit throttle, Ballistic EVO2 8 cell, Annitori RL quick shifter, Dunlop rubber.
Ninja187 is offline
post #7 of 23 Old 08-12-2007, 04:25 PM Thread Starter
Kwaky's Avatar
Thanks for the advice think I will go that route. Really the least thing I want to replace is the caliper's. I'd bend my Stock Brake lever's except my Levers are CRG and adjustable and damn near all the way out as is. They used to be only 1 or 2 clicks out. The only ZX14 calipers I found on ebay were around 400 at that time in the auction with 3 days to go. Don't see myself really jumping on that.
Kwaky is offline
post #8 of 23 Old 08-12-2007, 04:40 PM
The stock brake system is strong enough to stop a car and I can lift the back wheel off the ground from damn near any speed..... so
casey is offline
post #9 of 23 Old 08-12-2007, 05:02 PM Thread Starter
Kwaky's Avatar
20k miles down the line my brakes are definetly not what they once were. I have mad respect for the brakes I just want them as strong as they were or maybe a touch better? oh and Yes I have changed pads just in case someone asks lol
Kwaky is offline
post #10 of 23 Old 08-12-2007, 05:31 PM
Chickenstrip Eater
SUPER K's Avatar
Send a message via MSN to SUPER K
I just put my feet down Flinstone style,
http://i117.photobucket.com/albums/o45/josh10r/IMG_0144-1-1-1.jpg
Sent from your mom's IPhone using dirty fingers
SUPER K is offline
Shinko 003's--Reg or U-soft Cycle Concepts Vendors deals 5 06-29-2007 01:32 PM
Front brake feels too soft NYC_ZX10 Performance and Tech 34 01-11-2007 08:01 PM
Computer Codes Hard and Soft? crispin Performance and Tech 5 07-21-2005 09:42 PM
Soft saddlebags on the 10 majtii The ZX-10R 0 05-07-2005 05:14 AM
ZX10R brakes...Does the lever feel soft to you??? ZXTENR The ZX-10R 12 08-29-2004 11:16 PM
