Gen 1: 2004-2005 Smoked Led turn signals - Kawasaki ZX-10R.net
post #1 of 8 Old 04-08-2013, 07:06 PM Thread Starter
Gunny's Avatar
Ok, so i bought some smoked turn signals for my gen 1. Well today i went to install them. The turn signals i got were 3 wires red, green, and black. the wires on the bike(clutch side) are green and black/yellow stripe. black and black/yellow stripe are the ground. i tried hooking up just the green to see if it was color coded and maybe the red goes to a flash relay but thats not the case. any one have any info what the red and green are? im assuming red is power but then what is green?
Gunny is offline
post #2 of 8 Old 04-08-2013, 08:02 PM Thread Starter
Gunny's Avatar
well im an old man and have to get up at 430 to go to work so i guess ill finish this install tomorrow. so please someone hook me up so i can get home and knock this shit out!
Gunny is offline
post #3 of 8 Old 04-09-2013, 05:38 AM Thread Starter
Gunny's Avatar
Well I sent them an email asking which wire is which and they told me that the red and the green are both positive wires. They told me to just hook the green up because its brighter and the black because its the ground. With that being said, thats how I hooked it up in the first place and it didnt work so I guess ill try the red wire.
Gunny is offline
post #4 of 8 Old 04-09-2013, 06:48 AM
That sounds terribly complicated for a set of blinkers.
Sorry you having so much trouble. Id probably think that the red is positive.. but in any case id snap my seat off and connect those wires to the battery and just play with it until i figured it out.
sckrocodile is offline
post #5 of 8 Old 04-09-2013, 09:06 AM
95zx9r's Avatar
its gotta be 2 of the 3 wires! just take the turn signal to your battery and start toughing wires on the terminals till it lights up. your bulb may also be gone. that happened to me. installed everything didnt test. didnt work. bulb was gone.. brand new. replaced bulb with one from stock signals and good to go.
07 ZX10R - Full BEET exhaust, Attack rear sets, ASV levers, PC3, Speedo healer, GIPRO /w ATRE, -1+2 Vortex sprockets /w 525 DID gold chain, Rifleman 1/5 throttle conversion, K&N Air/Oil filters, Nissin ZX14 calipers, Goodridge front and rear steel braided black lines, Driven D3 Gas Cap, TechSpec grip pads, HID dual lights, Smoked signals and tail light, Zero Gravity smoke windscreen, Corbin seat, Grips, Bar ends, Fender eliminator, Servo eliminator, Secondary butterflies removed. etc... $$
95zx9r is offline
post #6 of 8 Old 04-09-2013, 03:05 PM Thread Starter
Gunny's Avatar
Thanks ill try the battery thing. Theyre led so I hope they aren't bad. Ill check the red wire in about 45 minutes. Theyre gonna look good if they work lol
Gunny is offline
post #7 of 8 Old 04-09-2013, 05:24 PM Thread Starter
Gunny's Avatar
Got it done! Posting pics up in the What did you do to your bike today? thread!
Gunny is offline
post #8 of 8 Old 04-11-2013, 11:34 PM
sksksks's Avatar
Did you buy this off e-bay? I remember buying one for my R1 a while ago and I could not get it to work to matter what I did. Could you post a pic of how you connected it? I'm looking into purchasing one for my 10r too.
sksksks is offline
Gen 2: Smoked front turn signals $30 shipped jettaglx91 Parts, Gear and Accessories 7 03-28-2013 05:18 PM
FS: Clear Alternatives Smoked Front turn signals Lucky10R Parts, Gear and Accessories 0 02-08-2009 10:13 PM
Installed LED turn signals KDiesel The ZX-10R 13 12-25-2008 11:16 PM
06-07 LED turn signals installed coastiepete The ZX-10R 13 03-06-2008 08:47 AM
LED Turn Signals besides CustomLED.com? JLove The ZX-10R 22 05-10-2004 06:37 PM
