Gen 1: 2004-2005 small oil leak? - Kawasaki ZX-10R.net
post #1 of 3 Old 07-25-2014, 10:54 AM Thread Starter
small oil leak?
I was at work one day and noticed some oil on some of the hoses on the lower left side of the bike. got home, took the lower fairings off and it was caked up with road grime, mixed with oil. i do think i found the main reason for the oil leak, a tiny crack in the engine crank case cover. but when i was cleaning up under the bike while it was on stands, i noticed something funny, it looks like theres a small chip in the block on the back side of where one of the bolts for the crank case cover goes through. would this also be a point where oil could be leaking from? might not be the best description but i got a picture of both.
ID:	275969   Click image for larger version
ID:	275977   Click image for larger version
1RawTi10 is offline
post #2 of 3 Old 07-25-2014, 03:55 PM
keithk's Avatar
Its probably just the crack, that's not a chip that's how it is made.
Its green and it says Kawasaki ninja zx10r on it!
keithk is offline
post #3 of 3 Old 07-28-2014, 05:12 AM Thread Starter
That's what I was wondering. Thanks
1RawTi10 is offline
Gen 1: oil leak djdarkmunk The ZX-10R 27 09-17-2013 10:34 PM
Oil Leak/Oil Light Justin Performance and Tech 12 03-06-2010 05:42 AM
URRGGHH!! Oil leak after oil change at stealership mark896 The ZX-10R 12 06-27-2009 03:00 PM
Oil leak issue... oil in airbox calie0 Performance and Tech 10 04-22-2009 10:08 PM
small antifreeze leak...? Brandon Performance and Tech 8 04-02-2007 07:23 PM
