Gen 1: 2004-2005 Small issue after frame swap - Kawasaki ZX-10R.net
post #1 of 6 Old 05-25-2012, 08:47 PM Thread Starter
Small issue after frame swap-speedo reading @ idle
Just finished a frame swap today with my 05 zx10r. After i start the bike the speedo is reading 5 or 6 mph at idle as i give it gas it climbs in mph.
Ground issue? The only solid ground i remember pulling is under the gas tank. And its in and tight.
Any ideas?
Tia
baiz is offline
post #2 of 6 Old 05-28-2012, 01:42 PM
10roller's Avatar
ive swapped a couple frames, thankfully ive never run into this problem. definately sounds electrical/sensore related.
you get this sorted yet?
10roller is offline
post #3 of 6 Old 05-30-2012, 10:46 AM Thread Starter
I did, i had been waiting for my new chain to come and therefore there was no chain on it.
After alot of searching i got the idea to look at that front sprocket, saw a sensor and the light bulb came on . so started it up and watched it, sure enough it was spinning even though it was in neutral. Threw the old chain back on and problem solved. Had me stumped for awhile.
Now if i could get only get my @#$%^&* gas tank open, have oiled it, smacked it, pulled the fuel pump to try and get inside. It will not unlock. Its stuck solid after sitting for a couple years.
baiz is offline
post #4 of 6 Old 05-30-2012, 11:16 AM
tjunkie's Avatar
Spray penetrating fluid on it daily. It'll open up eventually
tjunkie is offline
post #5 of 6 Old 05-31-2012, 12:03 AM
Post Whore
-Op-'s Avatar
wd40 ftw!!!
-Op- is offline
post #6 of 6 Old 05-31-2012, 12:37 AM
bluedevil's Avatar
guess my PM advice worked too good deal
bloo
bluedevil is offline
Gen 2: Frame Swap ZSex10R The ZX-10R 19 03-04-2012 10:51 AM
Gen 1. need advice on frame swap?????? jjkawasaki The ZX-10R 13 11-25-2011 07:26 PM
frame swap dashadler The ZX-10R 21 08-07-2009 02:18 PM
Few small parts to swap shift Parts, Gear and Accessories 2 05-31-2008 10:17 PM
Small Break Issue??? v.Hit The Brakes A Little Too Hard ASIANPRIDE Pictures and Videos 5 09-06-2007 12:23 PM
