Slipper clutch, How do i use it, do I need to use it, is it all just hype?? - Kawasaki ZX-10R.net
post #1 of 2 Old 08-09-2008, 04:22 AM Thread Starter
Sorry for the noob question but knowing I have a slipper clutch on my 08 I did a hard downshift and damn near went over the front end of my bike. lol
b4tn is offline
post #2 of 2 Old 08-09-2008, 06:45 AM
Supercharged Mod
There is nothing to "use". When the back-torque reaches a certain threshold, it operates automatically. It still allows enough back-torque to allow full engine braking without the clutch slipping, and it has to be like this, otherwise the engine would drop to off idle every time you closed the throttle. So a rough downshift will still give you a fair bit of engine braking, but the slipper clutch will cut out only the sharp impact the moment you let out the clutch with the engine speed way too low. This should cut out most of the rear wheel hopping that would otherwise happen.
I'm not 100% sure but I think on the newer versions of these clutches, you can change the threshold where it takes effect by changing some shims inside the clutch.
GoFaster is offline
slipper clutch dans450 The ZX-10R 26 10-16-2007 10:05 PM
slipper clutch? Jumboslax Performance and Tech 26 08-30-2007 04:52 AM
Slipper Clutch evander Performance and Tech 21 10-10-2005 09:57 AM
slipper clutch & clutch plates... jarhead05 Performance and Tech 14 07-07-2005 03:13 AM
What is a slipper clutch? ssg_hart The ZX-10R 6 01-05-2005 07:47 AM
