Shout out to gen 3 owners with speedohealer v4 - Kawasaki ZX-10R.net
post #1 of 7 Old 05-04-2011, 03:25 AM Thread Starter
Kawawog's Avatar
Send a message via MSN to Kawawog
Well as it seems , ive stumbled onto a werid little problem with my speedohealer v4 on my gen 3..
Today i noticed that everytime i hit my top speed recall button it adds more km's(miles to you's) to the trip meter
Just wanted any other people out there with the same setup to test theirs to see if it does it too, and get back to me?
Cheers
Kawawog is offline
post #2 of 7 Old 05-04-2011, 06:40 AM
DRFLGD's Avatar
Cheers
Normal!
It does that on all my bikes with speedohealers!
DRFLGD is offline
post #3 of 7 Old 05-04-2011, 07:23 AM Thread Starter
Kawawog's Avatar
Thanks champ, load off my mind
Kawawog is offline
post #4 of 7 Old 05-04-2011, 07:48 AM
SkyDork's Avatar
The odometer works by calculating distance based on the speed over a certain amount of time. There isn't a separate sensor for the mileage. When you press the top speed recall, the cluster thinks you're moving at that displayed speed for the 2 seconds and starts calculating distance traveled at that speed. It's completely normal as the 2 functions are related. It's insignificant though, especially because the total mileage on the bike will be lower by the same factor that's programmed into the speedohealer.
It's amazing how many people install the speedohealer and then complain about gas mileage going down because they're using the odometer for reference.
#WordCrimes
SkyDork is offline
post #5 of 7 Old 05-04-2011, 07:56 AM
Just trolling
yellow10r's Avatar
I didnt know this. Does the speedohealer not correct % off the speedohealer? Thus the mileage should be correct on the trip odo?
Originally Posted by scout View Post
I'd change the oil in that...and all the time.
Panigale 1199S
yellow10r is offline
post #6 of 7 Old 05-04-2011, 08:41 AM
SkyDork's Avatar
If you have a -10% correction factor in the speedohealer, then essentially the odometer is off the same percentage, as it thinks the speed is lower and thus makes the mileage lower. Trip meters, odometer, etc. it makes no difference as they all come from the same calculation. The only input to the cluster is speed. Distance is calculated based on this single speed input. Once you program the speedohealer to show the proper speed, everything else is affected accordingly.
#WordCrimes
SkyDork is offline
post #7 of 7 Old 05-04-2011, 09:20 AM Thread Starter
Kawawog's Avatar
Thanks for clearing that up dude
Kawawog is offline
shout box? jblaze The Out House 0 06-17-2009 11:06 AM
Shout out to Cyemm... zx10r_guy The Out House 1 08-23-2007 05:19 PM
Shout out to Texas chicozx10 The Out House 5 09-22-2005 11:14 AM
A shout out to all you father's.... R1GSXRKILLER The ZX-10R 22 06-19-2005 01:14 PM
Shout out to hc_performance Catfish_ The ZX-10R 0 09-09-2004 11:11 AM
