Gen 4: 2011-2015 Shock Spring Rate/ Replacement - Kawasaki ZX-10R.net
post #1 of 4 Old 05-02-2011, 07:57 PM Thread Starter
bikefanatic's Avatar
Does anyone know who makes heavier springs for the Gen. 4 rear shock? Race Tech hasn't made one yet. They haven't had a 2011 ZX-10r to spec out yet. According to their website fitment charts, I need a 10.7 kg spring (or closest fit), and stock is 10 kg. I figure I may as well change out the spring while I am in there to adjust the ride height with spacers. Any help is much appreciated.
bikefanatic is offline
post #2 of 4 Old 05-03-2011, 11:54 AM Thread Starter
I am sure the racers are simply replacing the shock, but I have a hard time believing that none of the other Gen 4 owners has sourced a different weight rear shock spring. I don't believe one spring rate works for everyone.....
post #3 of 4 Old 05-03-2011, 03:53 PM
RPG76's Avatar
If you know the length (measured unloaded) and internal diameter of your stock spring, you can order a spring from Hyperco or Eibach. If I did the conversion right, your looking for a 600 pound/inch rate spring.
05 ZX10r "the Mongrel": GP Suspension rebuilt forks, LE Penske double shock, 05-06 ZX6rr shock linkage, Brembo RCS MC, Nissin calipers (best mod for this bike!!!), Attack rearsets, Motion Pro Revolver throttle kit, ASV clutch lever, Champs sliders, smoked Zero Grav DB, Ti caliper bolts, CF fender, Renthal grips, Speedo healer, Maviryk MDA123 batt, Supersprox +3 520, That's it..... For now
190/55>190/50
RPG76 is offline
post #4 of 4 Old 05-03-2011, 05:13 PM Thread Starter
I was hoping to have the new spring in hand before removing the shock, so I could keep the bike's downtime to a minimum. Race Tech could provide one as well if I gave them all of the measurements. I may just need to take it to a good local shop...
Specs for '08 ZX10R shock? Spring rate and overall length. TheFleshRocket The ZX-10R 0 09-14-2008 12:18 AM
Spring Rate 06/07 rated zx Performance and Tech 19 08-26-2007 11:21 PM
Factory 05 rear shock spring rate? Vince10R Performance and Tech 4 06-16-2007 09:12 PM
Stock fork spring rate for 05'? Otis Performance and Tech 4 08-18-2006 02:38 PM
06 stock spring rate Katmanblues Performance and Tech 1 04-12-2006 06:48 PM
