shock ? - Kawasaki ZX-10R.net
post #1 of 8 Old 11-01-2010, 12:04 PM Thread Starter
tone.r's Avatar
shock ?
who sells a stiffer rear spring for the 04-shock?
tone.r is offline
post #2 of 8 Old 11-01-2010, 12:59 PM
zx racer's Avatar
have you thought about swapin the stock shock out for a busa shock, much stiffer and is a direct swap.
zx racer is offline
post #3 of 8 Old 11-01-2010, 01:00 PM
Sebastian1000's Avatar
Eibach
Sebastian1000 is offline
post #4 of 8 Old 11-01-2010, 03:47 PM Thread Starter
tone.r's Avatar
I got a reval shock its working very well just thinking about puting a stronger spring on it, im about 200lb and i want a better spring
tone.r is offline
post #5 of 8 Old 11-01-2010, 04:37 PM
themightymezzo's Avatar
http://www.traxxion.com/HypercoShockSprings.aspx
Not sure if this is what you're looking for or not.
After rereading the thread sounds like you already replaced the stock shock but I'll leave the below information for others just in case.
I think the 05 spring was a bit softer and better valving than the 04 but not 100%. I think the stock spring is something around 530 pounds. I think you would want to start with setting sag first and then see how it feels. If you have already done that and still don't like it from what others have said you should just have the stock shock revalved/resprung by DK racing or one of the other suspension companies. Just respringing the stock shock probably won't get you the results you are looking for since it's not only a spring issue.
Just my opinion.
themightymezzo is offline
post #6 of 8 Old 11-01-2010, 06:40 PM Thread Starter
tone.r's Avatar
Just my opinion.
thanks good info
tone.r is offline
post #7 of 8 Old 11-02-2010, 12:41 AM
JLAudio11's Avatar
I just swapped to a first gen busa shock and love it. I've heard of people swapping just the spring too. Otherwise racetech will sell you a spring, I believe they're around $100.
JLAudio11 is offline
post #8 of 8 Old 11-02-2010, 08:16 AM
mdzx10r's Avatar
I have an Eibach spring on Ebay right now for sale if you are interested. I believe the spring is rated for 1100lbs. I ran it on my 08 with about a 6" to 7" stretch and it felt good.
http://cgi.ebay.com/ebaymotors/Eibach-rear-spring-heavy-duty-motorcycle-/110606051854?pt=Motorcycles_Parts_Accessories&hash =item19c0a26a0e
mdzx10r is offline
04-05 shock tank zx10r Wanted: Buy or Trade 3 06-07-2008 12:06 PM
Does an 06 shock fit a 04/05? medicdad2005 Performance and Tech 9 07-03-2007 02:51 PM
04/05 10r shock=03/04 gixxer 1000 shock? Hoser Performance and Tech 30 12-12-2006 06:10 PM
04/05 Shock D Parts, Gear and Accessories 4 05-16-2006 05:31 AM
05 636 shock vs 04-05 zx10R shock Vonstallin Race and Stunt 0 09-25-2005 12:40 AM
