Gen 1: 2004-2005 shim????? - Kawasaki ZX-10R.net
post #1 of 6 Old 07-30-2012, 09:39 AM Thread Starter
tone.r's Avatar
shim?????
How would you know if you spit a shim out??
Tone.R {checkmate}
Do what makes u happy whatever it is.....Roberson Racing
tone.r is offline
post #2 of 6 Old 07-31-2012, 03:52 AM
thundercoupe9's Avatar
I would think that the valve wouldn't close all the way and your engine will get louder and will have a miss.
thundercoupe9 is offline
post #3 of 6 Old 07-31-2012, 07:01 AM Thread Starter
tone.r's Avatar
I've been paranoid but it's running real good. It seem louder to me
Tone.R {checkmate}
tone.r is offline
post #4 of 6 Old 08-01-2012, 08:59 PM
crater2114's Avatar
Send a message via Skype™ to crater2114
proper way
alright man. if you throw a shim out you definitely will hear it. But don't start tearing down your engine until you know exactly where the noise is coming from. But the only way to check is take the tank, and airbox, and head cover.( those rubber gskets can be reused but i recommend for the best seal to use a new one, and use the (TORQUE PATTERN CORRECTLY!)). Then take off the head and the side inspection covers and put the engine at top dead center on each individual cylinder and look at the clearances on all the valves. (while checking obviously look at each shim and see if its there.) If you suspect a bad shim put which ever cylinder it says to put on to remove the camshafts. (either 1st or 4th)Once the cam tensioner, cams and chain have been removed, measure each individual shim and make sure it is in spec. of what application you are using whether it is race, or stock. Once you do that you will be able to tell of any wear on the top end. If you have any questions fill free to message me man. hope all goes well!
crater2114 is offline
post #5 of 6 Old 08-01-2012, 09:01 PM
crater2114's Avatar
but i highly doubt this mainly because its a shim under bucket. lol
post #6 of 6 Old 08-03-2012, 12:12 AM Thread Starter
tone.r's Avatar
THANKS FOR THE INFO
Tone.R {checkmate}
tone.r is offline
Gen 4: Anybody have a How to shim your shock. trdtuner7 General Motorcycle Discussions 11 05-11-2013 11:35 AM
Gen 1: Valve Shim Size OD? bluedevil Performance and Tech 28 06-25-2012 12:25 AM
Valve Shim Swap?? ZxTennessee The ZX-10R 10 06-23-2012 10:47 PM
Gen 2: Valve Shim meanstreak5 Performance and Tech 19 04-28-2011 10:08 PM
04-07 cam shim kits jimbob8915 Performance and Tech 9 12-09-2010 08:15 AM
