Shifting Woes - Kawasaki ZX-10R.net
post #1 of 3 Old 03-06-2008, 10:53 PM Thread Starter
Shifting Woes
I'm having a problem with my quick shifter, its a Cordona quick shifter mounted on a 05 10r
On the first to second shift the transmission will shift into second briefly and then jump out of gear into neutral. I have the delay set at .085 milli seconds. Not sure if I need more time or if something else is causing a problem.
I was at the track this past weekend and this happened about every fifth or sixth shift.
I have aftermarket rear sets, but have not had a shifting problem until installation of the quick shifter.
I have it setup for standard shift, any ideas?
ccsd111k9 is offline
post #2 of 3 Old 03-07-2008, 12:09 AM
Update your machine with this since you track you bike. I had the exact same issues as you described. Scroll down to the shift star.
http://www.factorypro.com/Prod_Pages..._sell_the_bike.
desmokwan is offline
post #3 of 3 Old 03-07-2008, 12:02 PM
booken's Avatar
I was having a similar problem going from first to second with my PC quick shifter. My shift lever was too high. I lowered the position of my shift lever almost an inch and all is well.
booken is offline
K5 Woes part III ?? Austin10RPowers The Out House 22 07-25-2005 10:43 PM
More Gixxer Woes iroman The Out House 21 07-21-2005 06:35 PM
Suit woes modiggs The Out House 7 07-10-2005 11:25 AM
transmission woes trikchop Performance and Tech 25 01-27-2005 11:30 AM
Speedohealer woes Big Daddy The ZX-10R 13 06-29-2004 05:36 PM
