shifting question - Kawasaki ZX-10R.net
post #1 of 5 Old 08-18-2008, 01:47 PM Thread Starter
leemille's Avatar
shifting question
i have a zx10r engine in my race car. in order to get the drive train setup i wanted i had to remove the front sprocket cover. this also disables the speedo. now the question.
is the speedo input required in any way for the shifter to work correctly?
specifically, have i screwed up the neutral lockout?
will i go into neutral or will it shift into second when i shift up from first?
when i shift down from second it will go into neutral or first?
any input on this would be greatly appreciated.
"I'm your father, Luke!"
leemille is offline
post #2 of 5 Old 08-18-2008, 02:13 PM
Orange Juice's Avatar
It will operate normally.
Orange Juice is offline
post #3 of 5 Old 08-18-2008, 02:47 PM
FAF
Rent this space
The neutral lockout is mechanical, so no problem.
FAF is offline
post #4 of 5 Old 08-18-2008, 06:03 PM
bluedevil's Avatar
and to add if you look at the Schematic the Speed Sensor only outputs to the Cluster and you can run a bike without the Cluster....so basically it's just an Indicator signal and doesn't affect the ECU or mechanical systems.
bloo
bluedevil is offline
post #5 of 5 Old 08-18-2008, 06:57 PM Thread Starter
leemille's Avatar
thanks. i can aways count on getting the true answer for this forum.
leemille is offline
Down Shifting? Tread70 The ZX-10R 31 08-24-2006 06:02 PM
Shifting to first (06 10R) YZF The ZX-10R 17 05-09-2006 09:51 PM
shifting question tjvtsportsman The Out House 10 10-02-2005 09:09 PM
shifting question for you smrat people king-tony Performance and Tech 6 05-05-2005 08:15 PM
GP shifting ? ? packetsmurf The ZX-10R 32 03-14-2005 01:50 PM
