Shifting problems - Kawasaki ZX-10R.net
post #1 of 18 Old 03-20-2005, 01:02 PM Thread Starter
bellevuetlr's Avatar
Shifting problems
Anyone else have problems shifting from 2nd to 3rd under full load? Its starting to get on my nerves. Any solutions to this?
bellevuetlr is offline
post #2 of 18 Old 03-20-2005, 03:59 PM
Andy's Avatar
Images: 25
Ya might have better luck over here.
Andy is offline
post #3 of 18 Old 03-20-2005, 04:08 PM
Post Whore
Older Guy's Avatar
Put a 10 oz can of Microlon in it...shifts much better...I bitched a lot about the shifting...now it's fine...
Older Guy is offline
post #4 of 18 Old 03-20-2005, 05:03 PM Thread Starter
Thanks guys...
post #5 of 18 Old 03-20-2005, 06:31 PM
Andy's Avatar
Images: 25
It loosens up after the break in too. If that applies to you.
Andy is offline
post #6 of 18 Old 03-20-2005, 06:45 PM Thread Starter
i already have 4700. do you know if kawasaki has a recall for this?
post #7 of 18 Old 03-20-2005, 07:47 PM
crispin's Avatar
Send a message via AIM to crispin
It is the way it is going to be.
Read my review of the 1000 RR
One of the things I mentioned is that the Honda will shift into 3rd under full power.
I have had some issues street racing with that stupid 2-3 shift
You have to mentally make yourself come off of power for a sec to make the shift happen.
ya ya ya...
crispin is offline
post #8 of 18 Old 03-20-2005, 08:04 PM
What do you mean "under full load"?
How are you shifting? Something has to be unloaded, clutch, gas or both. What method are you using?
Mike
BIKEMIKE is offline
post #9 of 18 Old 03-20-2005, 08:39 PM
You Might try reversing the shifter. You will have to get the dremel tool out and remove a very small amount of the left lower (fairing) to keep it from rubbing on the shift arm, but it is a very straight forward mod, and you will lessen the chance of missed shifts because now you will be pushing down to up-shift. It is also much easier to shift while on the back wheel with the GP pattern shift set-up. You will have to really pay attention for a while until you get used to it though, but it will feel right after a while.
Tony
MountainviewX is offline
post #10 of 18 Old 03-20-2005, 09:31 PM Thread Starter
under full load - what i mean is when im at the peak of the power band in 2nd and trying to shift to third. oh yes, i shift without the clutch lever~ once i hit the peak rpm i would ease off the throttle a bit (say 10 percent) to upshift.
MountainviewX, i dont think the clutch is slipping at all. it just wouldnt go into gear.
Gear/Clutch problems... hillcountry10r The ZX-10R 33 06-30-2005 07:14 PM
Engine problems with the 10? burgerkin The ZX-10R 11 10-09-2004 07:24 PM
Shifting Problems and parts cogthekneedragger The ZX-10R 10 06-21-2004 07:03 AM
Shifting problems? kwakman The ZX-10R 12 03-30-2004 06:39 AM
