Please forgive these ignorant questions, but I don't have a bike or linkages to look at as I try to figure out some stuff. I'm installing a bare 2005 ZX-10 engine into my race car.
1. I'm getting ready to design a shifter cable and need to know which direction the shaft turns for upshifts and downshifts. In other words, when the shaft turns clockwise (when viewed from the left side of the engine), does that induce an upshift or a downshift? I know I should be able to tell on my own, but haven't been able to figure it out yet.
I should mention that I bought the engine on ebay and assume it's good, but haven't run it yet, so it could have problems if the seller was sleazy.
2. Regarding the clutch - I've replaced the clutch springs with stiffer ones, but am not confident that it has gone back together correctly. I hope it has, but would like to confirm. I can easily move the lever by hand quite a distance without much resistance, but I guess that's not really doing anything inside. Since I don't have a working bike with linkage to look at, I'm not sure where the lever is when it starts to disengage, how far it will travel or how hard it should be to move (especially with non-stock springs). I'm hoping someone can suggest ways I can work the clutch with the engine out of a bike chassis, and that will help me determine things like cable length needed to run it to the car's clutch pedal.
Let me know if you need more info or pictures for this post to make more sense. I appreciate your help.
I am able to find neutral and one gear, but I'm not sure if that gear is first or how to engage other gears. Seems like it should be easy, but I haven't figured it out yet ...
And here's a picture of the clutch lever in it's normal state (clutch engaged).
My questions are:
- How far does it rotate from here before the play is taken up and the clutch springs begin to be depressed?
- How much further should it rotate to fully disengage the clutch? (or, asked differently, how close does the lever get to the cable mount?)
Yes, I've seen that arrangement, but doesn't sound great. I've raced cars for years, so a foot pedal will be most natural. I don't mind taking my hand off the wheel for a moment to shift, but declutching would be too much hand activity, IMO.
My current plan is to attach a cable between the clutch lever and a clutch pedal. It will be pretty similar to the bike arrangement, except with a foot pedal instead of a handlebar lever.
The problem is (and it's not a major problem, just a nagging feeling), it will be a while before I get to that because I have so many other things to tackle first, such as cooling, fuel, exhaust, wiring, etc. Meanwhile, I'd like confirmation that my recent clutch job went together correctly. When I pull on the lever now with my hand, it doesn't quite feel right. That could be because it takes a significant effort to depress the clutch springs - more than I can exert with my fingers on the lever.
Sorry not into those things but still think he's ahead of you when it comes to the ZX10R motor..he has a ZX10R powered race car//check him out as he is a real cool guy and sure he would help out if he can.:wink:
Consider this idea, I actually did this for a one legged guy in a legends car.
All your upshifts can be clutchless , so you dont need the clutch on the way up the box , connect the clutch cable to the shifter to pull when you downshift , with the right fulcrum points you can engage the clutch a fraction of a second before you down shift and leave you enough cable to pull away in first by holding the lever forward.
Or get a "Y" cable and have a pedal too.
To answer your question about the length of lever travel to disengage the clutch you are looking between 6 and 12 mm of movement depending on the stack height.
i didn't have room for another pedal in the footwell, so i have the clutch next to me ala sprint car. i installed a pingel electric shifter and a paddle shifter on the steering wheel.
i'm not home right now, but when i get home i can send pics of my installation if it would help.
buy or get the service manual, it will help with question like which direction for the shift.
i seem to remember, counter clockwise for first, clockwise for upshift. also won't go into neutral unless the speed is zero. also, it kluncks when going into first.
I'd enjoy seeing the pictures if it's easy for you to post.
I did look, by my service manual on CD didn't have it, at least not where I looked during 15 minutes of searching..
Based on the info from previous posts, I am assuming that once I'm in neutral, I twist the shaft clockwise to clunk it into first gear. Later, when I get the parts moving, I assume that upshifts from first gear will be counterclockwise twists of the shaft.
Related Threads
Kawasaki ZX-10R Forum
2.1M posts
128.9K members
Since 2003
