Shift drum? - Kawasaki ZX-10R.net
post #1 of 15 Old 06-04-2007, 11:39 PM Thread Starter
Shift drum?
Does anybody know if there is a shift drum out there that alters the shifting sequence of the bike.
example, stock is= 1 N 2 3 4 5 6
I'm looking for something along the line of the wsb and moto gp style.
example= N 1 2 3 4 5 6 with a neutral lock out
Just a though, I am still searching but haven't found anything for the 10r other than stock replacement.
Stock does not bother me but a shorter more positive throw from first to second would be nice.
YoungBlood is offline
post #2 of 15 Old 06-05-2007, 03:51 AM
Group B's Avatar
Do you have aftermarket rearsets?
I really like how my Attack rearsets have improved the shifting on my '05 10R, and I plan on installing a Factory Pro shift-star and detent arm in the future.
Group B is offline
post #3 of 15 Old 06-05-2007, 07:15 AM
FAF
Rent this space
You cant do it, it is more than the drum that selects the shift sequence, it all depends on where the gears are placed in regards to each other.
I did a thread once on how to remove the neutral position detent so you pass right through, you can still find neutral but its a bear for everyday riding.
FAF is offline
post #4 of 15 Old 06-05-2007, 03:40 PM
Group B's Avatar
I tried looking up your thread just for research, but your attachments wouldn't come up.
Any way they could be restored?
Thanks,
David
Group B is offline
post #5 of 15 Old 06-05-2007, 03:57 PM
FAF
Rent this space
Let me see if I still have the pics....I'll be back.
FAF is offline
post #6 of 15 Old 06-05-2007, 03:58 PM
FAF
Rent this space
FAF is offline
post #7 of 15 Old 06-05-2007, 04:01 PM
FAF
Rent this space
You can see from the pic that the detent for locking neutral is removed so you get a straight pass through to second.
This is a quick fix however you wont have neutral(basically dogs fully engaged either in 1st or 2nd)
FAF is offline
post #8 of 15 Old 06-05-2007, 04:04 PM
FAF
Rent this space
Unfortunately you couldnt get neutral at the beginning as it is basically located in the void between two gears , all the detent does is stop the drum from full rotation to engage the next gear.
FAF is offline
post #9 of 15 Old 06-05-2007, 04:07 PM
FAF
Rent this space
Way back in the stoneage when I used to race bikes , we would fill the detent with weld and use a stronger spring on the pawl to fly through gears, you could just about find neutral when the engine was stopped, if you were lucky.
FAF is offline
post #10 of 15 Old 06-05-2007, 04:11 PM
FAF
Rent this space
Part no 13236a and spring can be replaced with a pawl with larger roller and stiffer spring , this makes engagement real easy as the larger diameter roller doesnt sit in the well of the shifstar as much but is held there with greater spring pressure.
FAF is offline
Black Drum Fishing On The Delaware Bay DANGER10R The Out House 3 06-03-2007 03:42 PM
FS: Pearl Export Series 5pc Drum Set Riddick Garage Sale 6 08-07-2006 01:52 PM
06 636 gp shift aussie70 ZX-6R & ZX-6RR Archives 1 05-28-2006 09:11 PM
Amazing drum solo by a 12 year old kid grego10r Pictures and Videos 2 09-24-2005 02:33 AM
shift help??? green dragon The ZX-10R 0 06-19-2005 05:28 PM
