Gen 2: 2006-2007 Secondary Eliminator - Kawasaki ZX-10R.net
post #1 of 17 Old 08-15-2012, 11:16 PM Thread Starter
wetley's Avatar
Has anyone figured out, or stumbled across a company, that's been able to make a module to eliminate the secondary butteryfly motor and sensor?
wetley is offline
post #2 of 17 Old 08-16-2012, 06:35 AM
BGoodwin22's Avatar
As far as I know there isn't anyone yet. Servobuddy makes one for the gen4, and I have contacted them multiple times asking if they have plans to male one for the early models, to which I always get the response "not at this time". I am very interested in this for my gen3 as well, maybe this thread will uncover something new besides having the ecu reflashed.
BGoodwin22 is offline
post #3 of 17 Old 08-16-2012, 07:16 AM
CMEJATT's Avatar
You mean remove the servo motor?
CMEJATT is offline
post #4 of 17 Old 08-16-2012, 12:15 PM Thread Starter
wetley's Avatar
ya, i was a tester for a module they tried making. it didnt work and when i sent back the feedback they simply replied "we will not be continuing this project at this time"
i already removed the motor and sensor. i just dont want the FI light and limp mode
wetley is offline
post #5 of 17 Old 08-16-2012, 04:38 PM
thundercoupe9's Avatar
I don't think it puts the bike in the limp mode, I pulled mine out and it runs too damn good to be in a limp mode
thundercoupe9 is offline
post #6 of 17 Old 08-16-2012, 04:42 PM
May i ask why you need to remove the motor and sensor ?
rickyzx10r is offline
post #7 of 17 Old 08-16-2012, 04:57 PM
CMEJATT's Avatar
Hit up hellsrazor he sells Servo Eliminator Kits ... very good .. i installed mines 1 , 2 . 3 ... lol .. and cost a lot less then anything else
https://zx-10r.net/forum/showthread.php?t=117962
https://zx-10r.net/forum/showthread.php?t=116572
CMEJATT is offline
post #8 of 17 Old 08-16-2012, 05:02 PM
why do you need to do this ...anyone ???
Ive had a good idea about these plates but i'd rather someone explained their function and the pros and cons of removing them so im sure..
post #9 of 17 Old 08-17-2012, 12:05 PM Thread Starter
wetley's Avatar
i had a FI light when my secondary sensor went out on my street bike, thing ran really rich on the low end cuz the bike automatically puts the butterflies all the way open even at 0% throttle and idel so the ECU compensates and dumps a ton of fuel in. i fixed the FI light and bike ran great again
weight
i dont need the exhaust servo, need the secondary butterfly servo (intake)
i removed them because i drag race and i want as much air flow as possible. tho the butterflies do open all the way when your at 100% throttle, you have to wait for your RPM/wheel speed to get up before the ECu starts opening them up and even then, the butterflies never fully open all the way. even if you get the ECU flashed to fix that probllem, you still have a 1/8 butterfly taking up airflow space. may not seem like a lot more air, but if you figure the surface area of the butterfly on end and the rod that goes thru the throttle bodies against the overall linear surface area of the throttle bodies and then think about the air turbulance the rod makes, it ends up being enough to make a difference; and when you're trying to get every hundreths of a second out of your bike little things like that are HUGE
wetley is offline
post #10 of 17 Old 08-17-2012, 03:52 PM
for your purposes that makes perfect sense..
Secondary FI always on DerekPearson Performance and Tech 2 09-22-2011 08:32 PM
secondary screws for a 2nd gen anyone have any ?? cholojr24 The ZX-10R 5 03-06-2010 07:00 PM
Secondary flys on the 08 LooseTooth Performance and Tech 17 06-12-2008 01:20 AM
Late secondary's ?? FAF Performance and Tech 2 05-25-2006 09:59 PM
Secondary Butterflies miykl Performance and Tech 96 01-13-2005 09:12 AM
