secondary butterfly question - Kawasaki ZX-10R.net
post #1 of 6 Old 09-10-2006, 10:42 PM Thread Starter
rojapar's Avatar
i have the tank and air cleaner off and am sitting there looking at the secondary butterflies and can't help myself any longer, so i take my finger and push them open to peek at whats down in there. i thought they were spring loaded and would "snap" back. well they just stayed open so i pushed the other side and put them back closed. did i screw anything up doing this? do they have to be recalibrated if you move them around?
rojapar is offline
post #2 of 6 Old 09-10-2006, 11:18 PM
Speed Freak
garth285's Avatar
nope everythign is fine, they are on a electrical actuator and they reset them selves everytoime the bike starts up anyways.
garth285 is offline
post #3 of 6 Old 09-10-2006, 11:41 PM
yep and whatever you do if you take the plates off do not take that bar out or youll be staring at a fi light forever.. dont ask..
deezuhl is offline
post #4 of 6 Old 09-11-2006, 12:14 AM
MIA Post Whore
miykl's Avatar
not true at all. At least on an 04. The only side effect to removing the bar is you lose your cold start fast idle b/c the linkage rides on the bar.
miykl is offline
post #5 of 6 Old 09-11-2006, 01:59 AM
hongthaomurphy's Avatar
would it be better to remove the bar if the plates are removed? my actuator is fried so i had to remove the plates , but i just left the bar in. the bar does nothing now but sit in the way.
hongthaomurphy is offline
post #6 of 6 Old 09-11-2006, 07:48 AM
well i assumed his was an 06 since its listed as "yellow" and as i said if you remove the bar youll be staring at an fi light.. then if you do have an issue with the bike you wont know cause the fi light will always be on..
deezuhl is offline
secondary butterflies and actuator hongthaomurphy Performance and Tech 13 07-16-2006 08:09 AM
Secondary TB butterfly's? CBRE Performance and Tech 48 07-04-2006 04:10 PM
secondary butterflys removed Vince10R Performance and Tech 6 06-26-2006 12:01 PM
Secondary throttle body butterfly servo calibration racindego Performance and Tech 3 07-12-2005 09:49 AM
Secondary Butterflies miykl Performance and Tech 96 01-13-2005 10:12 AM
