Secondary butterflies removed or TRE - Kawasaki ZX-10R.net
post #1 of 26 Old 04-16-2008, 07:51 PM Thread Starter
ikaika's Avatar
I just wanted to see what the consensus was on this topic. I want more low end grunt from my 08 ZX10R without having to change the gearing. I was looking at the most cost effective way to do this. Will removing the Secondary Butterflies (which is free and free is good) do this for me or should I get a TRE or better yet, should I do both!? Thanks for the help and advice again.
ikaika is offline
post #2 of 26 Old 04-16-2008, 08:51 PM
I havent done the secondaries yet, but from what has been said here secondaries is probably your best bet! there is a few threads about this topic that will give you more info. search'em up.
There's no such thing as horsepower overload or a bike that carries its front wheel too often.
j1000 is offline
post #3 of 26 Old 04-16-2008, 09:18 PM
BANNED
I would think that a TRE on the 08 will disable your Gear Indicator by making it read the same gear all the time. If your cool with that......
I don't know, maybe I just got a special one. Mine doesn't need any extra low end grunt. I put 90 miles on mine today and that f#cker just flat out flys.
Even out on the freeway I found it difficult to get past 8000 RPM's without going ballistic.
I entered onto the freeway down a sloping entrance and gave it full throttle in 1st gear and thought it was going to flip over.
Good Luck in your search for low end grunt!!!
JJ
JimmyJam is offline
post #4 of 26 Old 04-16-2008, 09:35 PM
JJ
I agree, before i really rode the bike i said i was doing secondaries and all that, but after doing some real riding on it, i dont see the low end being weak at all, this bike scares the shit out of me every time i ride it and i dont see the need to do anything right now. love it!
j1000 is offline
post #5 of 26 Old 04-16-2008, 09:56 PM
BANNED
I couldn't agree more. I had 35 easy miles on mine before going out today. Yes I have had the bike several months but it has been brutally cold or raining. Today was perfect. I rode an easy 10 miles over to the interstate, filled up with gas, crossed over the bridge, made a left onto the entrance ramp, going down hill and nailed it in 1st gear and I swear it would have flipped over. That scared the sh!t out of me.
I had a hard time out on the freeway getting much above 8000 RPM's as you are now going go to jail speeds.
I dropped down into 3rd gear at about 70 MPH, thinking then I could wack it and see what she will do, but the [email protected] thing wanted to power wheely like crazy and I had to back off.
This 08 far exceeds my 06 by a bunch. I just LOVE IT!!!
I have 130 miles on it now and changed the oil and filter after I got home and put in some Valvoline conventional oil. I will run that to about 600 miles then in goes the synthetic.
Gesus H Krist that bike hauls @ss. I was thinking about keeping my 06 until after today.
I can't beleive they can legally sell this sh!t.
JJ
JimmyJam is offline
post #6 of 26 Old 04-17-2008, 12:04 AM
spikespiegel's Avatar
Send a message via AIM to spikespiegel Send a message via Yahoo to spikespiegel
lol exactly, i was going downhill in a straightway before the turns got real twisty, so i decided to try and keep her pinned in 3rd (cause i haven't been able to in first and second in the top) and lo and behold, the front came up on me, IN 3rD! Going downhill!!!
Down low, it does have the grunt if you feed it a bit of revs, i still think other liters may have the edge, but its certainly not terribly slow down low. I'm gonna TRY the secondary fly removal after i pass 1200 miles (right now at 700+)
spikespiegel is offline
post #7 of 26 Old 04-22-2008, 08:23 PM
Initial impressions from doing secondary butterfly removal mod
Big thanks to Zxdave for helping me out with answering all my annoying questions regarding this mod.
I was wrenching on the MV earlier today putting on a ti rear subframe and thought i could probably do the 2ndary butterfly valve mod on the ZX while i'm in the mood. Now i know kawi's relatively well as i had a 07 6R and did also sorts of mods on it myself. THe 10R was a lot easier and better to work on.
In terms of easiness, I just took the airbox cover and the air-filter holder and the duct out, everything else remained intact. I just worked my way around the velo stacks and just used a #2 screwdriver and got the screws out one by one and then the valves. Simple enough, no heat , nothing.
Impressions: I'm at a 1000 miles now and know the powerband kind of well at this point. After this mod, it seems like there the little bit that the 08 lacked is taken care of with this mod. It DEF feels like the front will come up at 4-5k now or even earlier if you have the balls to keep it pinned lol. With almost 30 miles with this mod in the twisties I don't think the mod affects mid range or up top at all but I can definitely tell you that down low is way diff, more power for sure.
I was thinking about doing a front sprocket change but no need now, i'm VERY happy with the bike. Now it has the bitching low end that matches how insane the top is!
Oh and I also did some quick tests in going WOT in like 3rd or 4th gear, and there is no lag as I thought there might have been. Response is instaneous as before, there is no rough idling, theres no roughness at all anywhere. Just more power.
As I put more miles after this mod (stupid weather) I will have more detailed feedback. THis will be my fifth valve removal on the bike (counting the exhaust butterfly valve ) and I gotta say, I am LOVING these free mods! Any naysayers or doubters, do the mod, you will not regret it.
post #8 of 26 Old 04-22-2008, 08:54 PM
bluedevil's Avatar
Why are you messing with the 08 10R it still doesn't come close to what you post in another thread to the MV:
no way, the mv 312R is known for hitting 312kph which is i think 192mph and thats the "fastest" top speed on a prod bike. I believe the zx's are good for 185ish... and mine comes up in 3rd on power wihtout any sprocket mods...
or is one your track bike the other is
bluedevil is offline
post #9 of 26 Old 04-22-2008, 09:07 PM
not sure what you mean?
I'm messin with the 10R cause i love messin with stuff in general. The MV F4 Senna in my garage is not the same as the MV312R which has a "theoretical" speed of 312kph (hence the name). But anyway, what does that have to do anything with this mod?
post #10 of 26 Old 04-22-2008, 09:15 PM
bluedevil's Avatar
Gotcha, you were bragging about how fast or Slow the 08 is in top speed to the MV model you don't have, but have a water down version that can lift up in 3rd gear no problem without Gearing, but the 08 can't but this MOD helps ......never mind maybe I'm just getting tired of reading the same reports in 10 different threads so thought I would be different. I guess next time or maybe all the time I will just merge them ALL!!!!!!!!
bloo
how to remove secondary butterflies hesaves0211 Performance and Tech 790 09-28-2014 08:12 PM
how to remove secondary butterflies hesaves0211 How To... 1 03-26-2008 08:41 PM
secondary butterflies and actuator hongthaomurphy Performance and Tech 13 07-16-2006 07:09 AM
Secondary Butterflies miykl Performance and Tech 96 01-13-2005 09:12 AM
