Sealed swingarm for air shifter - Kawasaki ZX-10R.net
post #1 of 35 Old 11-17-2008, 04:56 PM Thread Starter
10R_Havens's Avatar
Not sure if this should go here or Strip, mods please move as needed.
I am wondering on the reasonableness of sealing my stock swingarm to create an air tank to run an air shifter. I have searched everywhere and haven't found much of anything. Found some swingarms available from McIntosh and Trac Dynamics, but I don't want to fork out that kind of money.
Has anyone done this?
10R_Havens is offline
post #2 of 35 Old 11-17-2008, 05:35 PM
inappropriate
hesaves0211's Avatar
Images: 67
not to get but this would also be a great concept for hidden no2 tanks
1ST GEN-10R 234hp/[email protected], GT2871RS, cometic gasket, tial bov/ex wastegate, BEGI FMU, WALBRO fuel pump,falicon clutch basket,race pak clutch,200/50 pilot,yana-shiki levers,.net wristband, WEGO III,PC3,GPR damper,cbr cals/Galfer SS brake lines,gp shift,1/5 throttle, 2NDARIES REMOVED <<click for how-to, *R.I.P D.J 10 Apr 04*
hesaves0211 is offline
post #3 of 35 Old 11-17-2008, 05:42 PM Thread Starter
10R_Havens's Avatar
Yeah, that is one possibility of it as well. I was thinking of using one side for an air shifter and if it worked well, trying to use the other for nitrous.
I have a spare GSX-R swingarm I will look over tonight to see what, if any, leaks it would produce. I know it's not even close to the same, but just something to look at until I can get some more information.
post #4 of 35 Old 11-17-2008, 05:45 PM
KawieKrazy's Avatar
not a new idea but a good one! re: Buell
KawieKrazy is offline
post #5 of 35 Old 11-17-2008, 05:49 PM
Shorty's Performance
madnessracing's Avatar
A friend of mine has one like that on his busa and he uses it for the air shifter.
madnessracing is offline
post #6 of 35 Old 11-17-2008, 06:22 PM
Speed Freak
garth285's Avatar
I think they stay with air shifters only because nitrous is run at 900+ psi where a shifter can be around 100 psi.... its possible just have to find the right TIG welder to do it....
garth285 is offline
post #7 of 35 Old 11-17-2008, 07:42 PM Thread Starter
10R_Havens's Avatar
Yeah, I considered that too. The pressure is so high, it may be easier to simply run a bottle for the nitrous. However, an air shifter would be a bit easier.
Question is how many leaks the stock swingarm would have? Or how bad the welds are?
post #8 of 35 Old 11-20-2008, 07:52 AM
redline659's Avatar
You can have it tig'd up. You could also try some JB weld. Its worth a quick shot.
Prolly work just fine.
redline659 is offline
post #9 of 35 Old 11-20-2008, 10:28 AM Thread Starter
10R_Havens's Avatar
I will look it over. However, I don't really feel like pulling the swing arm off to weld it up. If forced too, it would really add time to this project.
Still hoping someone has done this and will post up the results...
post #10 of 35 Old 11-20-2008, 01:13 PM
Postwhore with an 04
bcm0018's Avatar
Sounds like a good idea but I've never seen/heard of anyone doing it before. Good luck!
bcm0018 is offline
air shifter tone.r Performance and Tech 3 10-11-2008 11:33 AM
'04-'05 Shifter Peg ducatiryder89 Wanted: Buy or Trade 0 01-27-2007 05:30 PM
Sealed Playstation 3, 60 G For sale/trade Belbo Garage Sale 18 12-11-2006 03:14 PM
Electric Shifter or Air Shifter??? Stud_wit_style The Out House 8 10-19-2005 06:41 AM
POS Shifter Paul Sonderfan The ZX-10R 6 11-08-2004 08:41 AM
