Scotts Damper install Issue - Kawasaki ZX-10R.net
post #1 of 4 Old 04-05-2008, 10:16 PM Thread Starter
olec4's Avatar
I just installed the Scotts Damper for my 98 ZX9 rebuild, and when its mounted I can not get the key in the ignition.
Has Anyone had to cut thier key just to get it past the damper into the ignition?
olec4 is offline
post #2 of 4 Old 04-05-2008, 10:22 PM
bluedevil's Avatar
yep, on ZX10R as well unless you run the damper 180deg. out....you don't need to cut much but it's required.
bloo
bluedevil is offline
post #3 of 4 Old 04-05-2008, 10:40 PM
champ91's Avatar
PDF of the manual I found online.
http://www.scottsperformance.com/literature/manual.pdf
See step 14. You can mount in the reverse position. No key cutting required. But... its a little trick to get the link arm off to reverse. They do sell a puller to get it off if you need. Good luck.
champ91 is offline
post #4 of 4 Old 04-05-2008, 11:56 PM Thread Starter
olec4's Avatar
Thanks very much.
I thought I was going nuts here, Scotts should put something more detailed in the instructions based on application.
olec4 is offline
Scotts Damper install? Easy-yay/nay? fun2fly Performance and Tech 11 01-06-2008 03:07 AM
06 Damper Leak Issue BigDally The ZX-10R 18 08-23-2006 01:03 PM
Speedo Issue Post PCIII - TRE install ctjackster Performance and Tech 6 06-24-2006 12:34 AM
Scotts Damper Install fastburnzx-10 Performance and Tech 4 05-31-2006 12:10 AM
Scotts damper GB.. need 2 more! Solo-Moto-Parts Vendor Deals 2 06-26-2005 04:49 PM
