Scotts Damper install? Easy-yay/nay? - Kawasaki ZX-10R.net
post #1 of 12 Old 08-15-2005, 01:09 PM Thread Starter
Just trying to get the skinny for when my Scotts Damper shows up in the mail. Any special tricks or hassles involved? I'm assuming no drilling or anything like that? Is it tricky to get the nut off the top triple? Anyone know what size nut it is and does the front end have to be supported to remove the nut. I realize these questions are probably mundane for most but I've come to realize if anything crappy is to happen it will happen to me so I'll do everything I can to limit the surprises. Thanks in advance.
fun2fly is offline
post #2 of 12 Old 08-15-2005, 01:18 PM
PostWhore
GuitarPlyr's Avatar
Send a message via Yahoo to GuitarPlyr
naw, its pretty simple....the front end doesnt have to be supported, but while you are doing it you may want to check the steering head bearings and make sure they are tight....for that you need to support the bike on a stand so that you can have free motion of the steering....El Diablo helped me check mine before installing my Scotts, and it was very loose...You will have to cut the key to give clearance....head nut is 36 mm
GuitarPlyr is offline
post #3 of 12 Old 08-15-2005, 03:50 PM Thread Starter
Thanks for the info, much appreciated. I didn't know about the key cutting though. Must be a tight fit. I'd like to keep the originals intact though, can you get these keys cut at most places or do they have special chips in them?
fun2fly is offline
post #4 of 12 Old 08-15-2005, 04:02 PM
champ91's Avatar
Not the key cutting thing again. Try this. NO KEY CUTTING REQUIRED. Turn the damper 180 degrees. It will put the larger portion of the damper towards you. It still works exactly the same. No loss in performance or function. AND no key mod needed. I dont have a picture but its an old trick that has been done on several bikes who's keys interfere with the body of the damper.
champ91 is offline
post #5 of 12 Old 01-03-2008, 12:27 AM
i ordered...
a Scotts Damper and I'll PM message you when I get it. The install should be easy right? I don't have many tools besides some allens, crecsent wrenches etc.
vjhils is offline
post #6 of 12 Old 01-03-2008, 04:30 PM
With any luck, (two years later) he isn't still working on the install :-)
The good news is, Scotts is the best, for the real world especially requiring a wider range of conditions. (double :-) )
louemc is offline
post #7 of 12 Old 01-03-2008, 05:27 PM
i put one on in less than 10 minutes and ate a burger while doing it.
06450F is offline
post #8 of 12 Old 01-03-2008, 05:38 PM
BANNED
And Scotts don't leak, like that other brand. But that other brand is prettier, until it starts leaking, then it be a bunch of ugleee.
JJ
JimmyJam is offline
post #9 of 12 Old 01-03-2008, 07:01 PM
can we ride yet!?!?!?
coolgjc's Avatar
damn it! i wish i would have known this! had no idea that you could flip 180 degrees. hell i just threw mine on saw that the key rubbed and said fuggit! i got another key
just put mine on after X-mas. took about five minutes and a beer and a half to install
coolgjc is offline
post #10 of 12 Old 01-03-2008, 09:24 PM
BANNED
I don't think you can just flip it 180. You have to remove the arm, and reinstall it 180, then flip it and that should require a special arm puller tool from Scotts, though not to expensive, and can probably be done with out it.
But then again, what do I know. Mine fits on straight up with no key interference anyway. So like you said "fuggit!"
JJ
JimmyJam is offline
Scotts damper and stock headers The Duke Parts, Gear and Accessories 5 05-17-2006 06:45 PM
Steering damper install? busaforhire Performance and Tech 5 07-22-2005 10:52 PM
scotts damper modpup The ZX-10R 10 04-24-2005 11:23 PM
Does Scotts steering damper frequently need servicing? kwakzx10r Performance and Tech 5 04-04-2005 07:50 AM
SCOTTS damper is on! mods2come The ZX-10R 36 06-04-2004 01:50 AM
