scan the bike and now have a question - Kawasaki ZX-10R.net
post #1 of 27 Old 07-18-2010, 04:52 PM Thread Starter
zx racer's Avatar
hey guys im sure alot of you know i just picked up this 05 zx-10r about a month ago and the FI light was on when i bought it, picked up a service manual and scan the bike & from the service codes its showin the Exhaust valve sensor malfunction, wireing open or short bad... can anybody explain to me wat that means and how i go about fixin the problem...
05 ZX-10R SWB.
zx racer is offline
post #2 of 27 Old 07-18-2010, 05:00 PM
All show and all go 10r
JLG0987's Avatar
judging from your mods I'm assuming you've got a full system. Did you remove the exhaust servo motor? if so that's your problem, either plug in back in or get the ivan servo eliminator. They also might be a DIY one someone here but I'm not sure.
JLG0987 is offline
post #3 of 27 Old 07-18-2010, 05:38 PM Thread Starter
zx racer's Avatar
only thing i did was disconnect the exhaust servo cables down by the mid pipe, the exhaust valve under the rear seat is still pluged up...
05 ZX-10R SWB.
zx racer is offline
post #4 of 27 Old 07-18-2010, 05:50 PM
bluedevil's Avatar
maybe the cables are binding causing an error...you need to remove the cables completely..it's a servo motor trying to adjust
bloo
bluedevil is offline
post #5 of 27 Old 07-18-2010, 05:52 PM
welds like he has palsy
JP636's Avatar
I think in order to not get the error code, the cables have to be attached at both ends.
Originally Posted by green10 View Post
speakers on a zx10 is like shitting in your bathwater!!!
JP636 is offline
post #6 of 27 Old 07-18-2010, 05:56 PM
bluedevil's Avatar
which is why I said maybe the un-connected end may be "BINDING" causing an error up front to the BOX...otherwise I agree....you need to know how servos work and from my Air Force days dealing with servos in Radio applications I can see this would cause a problem. ...remove at both ends not just one and report back.
bloo
post #7 of 27 Old 07-18-2010, 07:09 PM Thread Starter
zx racer's Avatar
bloo
i do have the cables tied up by the rear brake resivor so that could be the problem...
oh i didnt know that... i figured the plugs leadin into the box had to be unplug for it to throw a FI code...
bloo
oh ok even when i had both cables hooked up with the stock can the FI light was still showin & with the exhaust cables both pluged up the exhaust valve stays open & doesnt close will that cause the FI light to show & throw up a code...
05 ZX-10R SWB.
zx racer is offline
post #8 of 27 Old 07-18-2010, 07:14 PM
JLG0987's Avatar
starting to sound like a faulty servo motor, that or the connector is dirty or damaged.
JLG0987 is offline
post #9 of 27 Old 07-18-2010, 07:14 PM
bluedevil's Avatar
wish you mentioned that first...always give details when wanting help or info. but yeah I am sure it did cause a F1.
bloo
post #10 of 27 Old 07-18-2010, 07:37 PM Thread Starter
zx racer's Avatar
yea thats wat i was thinking... plugs on the exhaust servo looks good & doesnt look dirty... how hard is it to change the exhaust servo out ? & with the new servo motor should i reconnect the cables or will i be fine with them unplug...
[/COLOR]
bloo
yea i appologize to you guys, bike only has 4k miles runs & starts up great just the FI light showin... are the exhaust servo's on the 1st gen bad about goin out ?
05 ZX-10R SWB.
zx racer is offline
scan the bike and now have a question zx racer The ZX-10R 2 07-18-2010 09:11 PM
Accord drop springs and OBDII Scan tool bradshow01 Garage Sale 2 01-05-2008 08:31 PM
F/S OBDII Scan tool & 90-97 Honda Accord 2.25" Lowering springs bradshow01 Garage Sale 0 07-08-2006 09:14 PM
It's mike scan of the month. rocketracermike Pictures and Videos 3 01-28-2006 03:43 AM
non-bike question Stud_wit_style ZX-10r.net Site Help, Suggestions and Questions 1 04-24-2005 11:06 PM
