sato slip on springs - Kawasaki ZX-10R.net
post #1 of 7 Old 04-05-2006, 12:34 PM Thread Starter
Hi
The sato slip on has been just installed to my 2005 ZX10R bike...the quality is exellent...but the upper spring is touching to the the pipe !!!
Any experiences and recommendations ? What to do....
At least I will remove that plastic shelters...
lespaul66 is offline
post #2 of 7 Old 04-05-2006, 01:02 PM
MIA Post Whore
miykl's Avatar
Leave the plastic in place. It's there to prevent noise from the springs. The touching is not a problem.
2011 Ninja 1K street
2004 636 track
miykl is offline
post #3 of 7 Old 04-05-2006, 01:11 PM
circusnuts's Avatar
My Sato setup looks the same, except I don't have the sleeves.
I like the Sato, but have to admit the mid pipe could fit a bit better. Can you move your pipe back and forth? Mine doesn't fit as tight as the Yoshimura RS-3 did.
Dress for the slide & not the ride
circusnuts is offline
post #4 of 7 Old 04-05-2006, 01:39 PM
Big Daddy's Avatar
Images: 38
the spring position and rub is normal for many systems & brands.
Big Daddy is offline
post #5 of 7 Old 04-05-2006, 02:21 PM
Post Whore
Sgtusmc96's Avatar
Leave the plastic it will help prevent fretting from the spring. Without it it will start rubbing the metal and eventualy rub a hole into it.
04 Green ZX-10R, Evo II Header, Evo Canister, PCIIIUSB, BMC Race Filter, Vortex adj. Rearsets, Scorpio Alarm, Scotts Damper, Ivan's TRE, Ivan PCIII USB Map, Ivan's Kleen Block-Offs, Clear Alternatives Flush Mounts, Puig Double Bubble, Mirror Blocks, Sho-gun sliders, 1/5 throttle, Hot bodies fender eliminator, Goodridge SS lines, pazzo shorties and exhuast hanger.
Sgtusmc96 is offline
post #6 of 7 Old 04-05-2006, 02:49 PM
05zx10pilot's Avatar
My akro is the same....no worries bro just get out and let it growl!
Well, I started out with nothing and I still have most of it...
05zx10pilot is offline
post #7 of 7 Old 04-06-2006, 01:50 AM
grunty-motor's Avatar
Question
just put one on too and pipe does move a bit. Never used the silicon, so maybe its something to do with that
Mmmm - let me have a think about that....
grunty-motor is offline
Sato slip on installation lespaul66 The ZX-10R 4 04-02-2006 09:20 PM
Sato Racing slip on lespaul66 Performance and Tech 14 03-03-2006 05:58 PM
Sponsors--- Sato slip on IG Ksan Vendors deals 1 09-27-2005 11:38 AM
Sato slip on Quethet The Out House 5 09-20-2005 02:47 PM
F/S Ti Sato Slip on! GusGus748s Parts, Gear and Accessories 10 07-08-2005 12:22 PM
