Sag confusion - Kawasaki ZX-10R.net
post #1 of 15 Old 08-11-2010, 01:46 PM Thread Starter
riding4life162's Avatar
Sag confusion
This is my first time doing this. So I am tinkering with my suspension trying to set my sag and I have these numbers for the rear:
Static sag: 495.3mm
Free sag: 518.6mm
Rider sag: 480.06mm
Which gave me : 38.54mm Sag
I am trying to get around 35mm, should I be compressing the spring of lengthening it to get down to 35mm?
riding4life162 is offline
post #2 of 15 Old 08-11-2010, 02:27 PM
JVT
Tighten it. Right now you have 38 with you on it, you want less movement to get to 35mm of change or sag.
JVT is offline
post #3 of 15 Old 08-11-2010, 02:30 PM
BratNetwork's Avatar
Check this video out:
http://www.onthethrottle.com/howto/s...sion-business/
BratNetwork is offline
post #4 of 15 Old 08-11-2010, 04:00 PM Thread Starter
Awesome thanks, For some reason I cant tighten it or loosen it. And I have a shock tool.
Originally Posted by BratNetwork View Post
This was one of the first things I found when searching the net, and the one I used to find my numbers up top but there are bits of info I thought he could have given to make the vid better.
post #5 of 15 Old 08-11-2010, 04:07 PM Thread Starter
Is it the same concept for the front? If I need to get a lower sag number I need to tighten, or compress the front?
post #6 of 15 Old 08-11-2010, 05:30 PM
I had the video bookmarked and when I went to it, it wasn't there. The one I sent you seems to be the one that replaced the original one I found. The original one was done a gsxr and was way more detailed and informed (also i think it was done in inches instead of mm). He covered actually adjusting the rear spring tension and setting rebound and preload and all that... kinda sux bc I was gunna use that video step by step to tune mine...
post #7 of 15 Old 08-11-2010, 09:58 PM
JVT
Yes, if you go too much it'll rest on the top out springs
JVT is offline
post #8 of 15 Old 08-11-2010, 09:59 PM
JVT
I'm 205lbs on my 2005 I have 3 rings showing on the forks for 32mm sag
JVT is offline
post #9 of 15 Old 08-11-2010, 10:39 PM
BANNED
ZX10Rracer's Avatar
Static sag: 495.3mm
Free sag: 518.6mm
Rider sag: 480.06mm
whats your free sag#'s....
EDIT: never mind I saw you posted that what is you weight?
ZX10Rracer is offline
post #10 of 15 Old 08-12-2010, 01:21 AM Thread Starter
Well I am riding an 2003 zx6rr and my weight is about 235ish with gear on. I think I got my sag good, I had my wife come out and measure while I sat on the bike.
These are the numbers I got:
Rear Susp.
Static sag 495.3mm
Unladen Free sag 518.6mm
Laden Rider sag 485.14mm
33.46 Rear Sag now after adjustments
Front
Static sag 14.1''= 358.4mm
Free sag 14.9''= 378.46mm
Rider sag 14.8''= 375.92mm
13.5''= 342.9= 37.56 Front Sag after adjustments
I hope these numbers are good. I rode for an hour or so today and I could tell within 5 minutes that it was better. I also put the compression and dampening back to stock settings. I know its probably not sufficient with my 230-235lb size but, the previous owner had had them all jacked up, everything was all uneven.
Squid confusion... Sike General Motorcycle Discussions 59 05-28-2009 04:23 PM
awkward confusion martin1o9 The Funny Pages 2 02-18-2009 07:14 PM
Racefit 06-07 ZX10-R Growler Re: Confusion Racefit General Motorcycle Discussions 12 11-09-2008 07:50 PM
PCIII confusion Redneck Rocket Performance and Tech 17 02-07-2008 11:31 AM
