Safety wiring - Kawasaki ZX-10R.net
post #1 of 4 Old 12-02-2008, 08:58 PM Thread Starter
stadanco's Avatar
Safety wiring
I thought I saw a thread with a link to front brake keeper pins that had holes for safety wiring a while ago and was hoping someone could point me in the right direction. I know some people pin the back side of them but are they drilling the holes themselves or buying pins pre-drilled,pins are a little small to be drilling by hand.
stadanco is offline
post #2 of 4 Old 12-02-2008, 09:34 PM
La Flama Blanca
9R to 10R's Avatar
Images: 102
Here you go
here is the part number from this website: TIPINBP011R
http://www.tastynuts.com/site/frames...shoponline.htm
9R to 10R is offline
post #3 of 4 Old 12-02-2008, 09:37 PM Thread Starter
stadanco's Avatar
tasty nuts lol. Thanks
stadanco is offline
post #4 of 4 Old 12-06-2008, 08:07 PM
ducatiryder89's Avatar
Images: 21
I drill mine myself. You will need alot of drill bits though. You will average one a bolt most likely. TQ the pinch bolts down to spec and remember what spec is so if you have to remove them when you tq them back down the holes will line up. Since the caliper bolts are tapered use a punch and mark wear you are going to drill. Pretty simple just time consuming.
2005 ZX10R Track Bike With Way To Much Sh*t On It!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
ducatiryder89 is offline
Safety Screw goodiemo Performance and Tech 12 01-23-2007 01:52 AM
Safety Wiring Oil Filter? zx10ragentblack Performance and Tech 5 05-21-2005 04:39 PM
gun safety cain772 Pictures and Videos 2 04-21-2005 11:49 PM
Safety wiring grnblur The ZX-10R 5 06-23-2004 03:56 AM
Need Help With Wiring or Wiring Diagram for 2004 ZX-10 cashes41 The ZX-10R 0 05-21-2004 03:24 PM
