Gen 3: 2008-2010 Running without that Rubber insulation, heat mat??? - Kawasaki ZX-10R.net
post #1 of 3 Old 06-14-2011, 06:52 AM Thread Starter
ke2012's Avatar
Long story short it didn't go back in.....obviously I will feel more heat but anything else be effected by runneing without it. The black rubber piece that goes over the valve cover, under the throttle boddies etc....primarirly this will be a drag bike. Thanks in advance.
ke2012 is offline
post #2 of 3 Old 06-14-2011, 07:04 AM
SkyDork's Avatar
There was a thread a couple weeks ago on this topic. No it won't hurt anything. You probably won't feel much more heat. The purpose of it is to cut the heat down going to the air box and fuel tank. The cooler those items run, the higher the power output. How much? Probably negligible power loss if anything at all.
https://zx-10r.net/forum/showthread.php?t=103237
#WordCrimes
SkyDork is offline
post #3 of 3 Old 06-14-2011, 08:17 AM Thread Starter
ke2012's Avatar
Thanks!!!!!
ke2012 is offline
Need some poly insulation foam board. slav The Out House 0 12-06-2010 06:28 PM
5mm rubber nut same as ????? Waterfreak66 The ZX-10R 2 04-20-2010 09:05 AM
Is it okay to remove the black rubber insulation panel on an 05 10R? PumpinIron The ZX-10R 5 06-15-2009 12:01 AM
need new rubber gsredhot01rt Vendors deals 5 01-07-2007 07:52 PM
WTB: Your 04/05 ZX-10R rubber motor heat shield CountDokoo Wanted: Buy or Trade 1 01-02-2007 02:52 PM
