Rt Frt brake grabbing more than the Lt Frt? - Kawasaki ZX-10R.net
post #1 of 6 Old 04-24-2008, 12:52 PM Thread Starter
Grease's Avatar
Images: 7
Send a message via MSN to Grease
OK, All...
I replaced my OEM pads with Vesrah RJLs for a track day. When I removed the OEMs, I noticed discoloration, but didn't think too much about it since they had over 10K on them.
After the track day, I removed the RJLs and inspected them. I could see that they had gotten VERY hot...but true to reputation...no fade ever occured that I could tell.
When I removed the left side to inpect/change, I noticed that they didn't have the discoloration from heat like the right side did. I presume that since I am still running the original brake line setup, single line to the right and a line going from the right to the left, that it may have something to do with that...or might there be a different issue of why one side could pull more than another? Since it has very little miles, I don't feel that it is possible that there is "junk" in the lines/calipers or any such thing like that.
Thanks for any help.
Bikes: '88 EX250 (sold), '86 Nighthawk S (sold), '03 ZX7R (R.I.P.s), '07 ZX10R (sold)
I don't like repeat offenders; I like dead offenders.
My idea of 'gun control' is putting as many bullets as I can into the same hole.
- Ted Nugent
Iím all for gun control, I just define it a little differently. If you can put 2 rounds into the same hole from 25 meters, thatís gun control!
- Jesse Ventura
God gave man a brain and a penis, but only enough blood to run one at a time. - Stephen E. Ambrose
Grease is offline
post #2 of 6 Old 04-24-2008, 12:57 PM
luckz88's Avatar
Send a message via AIM to luckz88 Send a message via Yahoo to luckz88
have you cleaned all the gunk up that builds up on the pistons? check those...one side my have more than the other side
NESBA #88
Madness Racing wishes he could handle the power of a GSXR
All my homies left this site
luckz88 is offline
post #3 of 6 Old 04-24-2008, 03:03 PM Thread Starter
Grease's Avatar
Images: 7
With that little bit of mileage?
- Ted Nugent
- Jesse Ventura
Grease is offline
post #4 of 6 Old 04-24-2008, 03:12 PM
luckz88's Avatar
You never know...
NESBA #88
luckz88 is offline
post #5 of 6 Old 04-24-2008, 03:21 PM
Big Daddy's Avatar
Images: 38
yes clean them with soap & H20 and tooth brush after pushing them outward a bit and then perhaps push the pistons in/out a few times prior to bleeding the system.
Big Daddy is offline
post #6 of 6 Old 04-24-2008, 03:40 PM Thread Starter
Grease's Avatar
Images: 7
strange thing is that it appears that it has done this from the beginning...being that the OEM pads also showed heat from one side and not the other...
- Ted Nugent
- Jesse Ventura
Grease is offline
Brake mod gone bad Gang Green Performance and Tech 8 11-22-2007 10:10 PM
Zx-6 brake pads much thinner than ZX-10 brake pads Musikkant54 Performance and Tech 1 08-31-2007 12:54 PM
04/05 10r -Pazzo (brake) and Goodridge SS brake lines JBJ Parts, Gear and Accessories 1 02-14-2007 10:15 PM
Brake lines and brake pads DareDevil Vendors deals 1 09-30-2006 08:49 PM
MD Product Review: Galfer's Sintered 1375HH Brake Pads and Brake Lines and Waves flatout Performance and Tech 4 11-04-2004 12:29 PM
