RPM class? - Kawasaki ZX-10R.net
post #1 of 12 Old 01-12-2006, 02:22 PM Thread Starter
RPM class?
So if your bikes peak HP is at 14,400 rpm what is the use of an extra 3,100-3,600 rpm?
Also how far off is the usual limit from the peak?
Perferd is offline
post #2 of 12 Old 01-12-2006, 02:47 PM
Ara
LE Post Whore
Ara's Avatar
Well, I think its mainly to allow for some over-rev.
Ara is offline
post #3 of 12 Old 01-12-2006, 02:51 PM
Ara
LE Post Whore
Ara's Avatar
And in case that didnt make any sense, over rev allows you to hold your gear for a little longer, say in a corner, before grabbing the next gear.
Ara is offline
post #4 of 12 Old 01-12-2006, 03:01 PM Thread Starter
That makes sense thank you...
So how much over rev is normal? Are we talking about a few hundred or a few thousand in over revs?
Perferd is offline
post #5 of 12 Old 01-12-2006, 03:34 PM
Ara
LE Post Whore
Ara's Avatar
On 600's i've seen 2-3.5k rpm sometimes. Ive noticed that on a 1000, its usually less, maybe like 1-1.5k at most.
Ara is offline
post #6 of 12 Old 01-12-2006, 11:16 PM Thread Starter
so 3,100-3,600 rpms over rev is out of the question?
I am just asking cause the peak HP on the 06 6R is 14,400 but the limit is supposed to be 17,500-18k
Perferd is offline
post #7 of 12 Old 01-12-2006, 11:18 PM
dr_wookiee's Avatar
Send a message via AIM to dr_wookiee Send a message via MSN to dr_wookiee
Don't you mean the R6?
dr_wookiee is offline
post #8 of 12 Old 01-12-2006, 11:21 PM Thread Starter
Yeah but you knew what I meant...
I am just wondering why so much over rev?
Perferd is offline
post #9 of 12 Old 01-12-2006, 11:24 PM
Green Knight's Avatar
Send a message via MSN to Green Knight Send a message via Yahoo to Green Knight
cause it sucks banging off the rev limiter in a corner trying to pass someone. Shifting mid corner isn't a very good thing to do, up or down. Good way to spin up the back end.
Green Knight is offline
post #10 of 12 Old 01-12-2006, 11:26 PM Thread Starter
That makes sense but do you need 3,100 more? Ara said like 1-1,500 extra...
Perferd is offline
Idle RPM nachszx Performance and Tech 14 04-21-2007 01:36 PM
What's your favorite AMA class? bman33 Race and Stunt 11 05-18-2005 02:23 PM
What RPM you running at idle fast1 The ZX-10R 21 05-04-2005 04:25 AM
2004 open class comparison, by 2 oldish fools from Brisbane Afrodesia The ZX-10R 11 06-01-2004 09:50 AM
