Rpm - Kawasaki ZX-10R.net
post #1 of 6 Old 01-24-2011, 10:12 PM Thread Starter
tone.r's Avatar
Rpm
What's RPM's web site thanks, anybody running there oil pan?
tone.r is offline
post #2 of 6 Old 01-25-2011, 05:14 AM
codyc_13's Avatar
This one?
http://www.rpmcycleperformance.com/
Hope that helps.
codyc_13 is offline
post #3 of 6 Old 01-25-2011, 08:42 AM
sweetride10r's Avatar
I had one on my bike worked well just watch the pickup. Ive heard that the fall off. Never happened to me but heard it has
sweetride10r is offline
post #4 of 6 Old 01-25-2011, 06:44 PM
cow10r's Avatar
I bought one used and the o-ring that came with the pickup (i don't know if its the one RPM provides) would not have sealed it to the motor so i cut the bottom of the factory seal off and made my on o-ring. If you get one you will see what im talking about. I also heard of them falling off so i drilled and tapped another set screw and used lock tight. I was kind of paranoid so i welded a slug to the bottom of the pan so if for some reason it did, it wouldn't fall off completely and i would see a drop in pressure. I havent had any problems .
cow10r is offline
post #5 of 6 Old 01-25-2011, 07:52 PM Thread Starter
tone.r's Avatar
thanks guy's thats why i was asking, i have a friend that got one for sell but i heard some of the same stuff, I was told that you have to pull them down and keep a eye on that pick up, thanks again
tone.r is offline
post #6 of 6 Old 01-25-2011, 08:26 PM
gbillzx10r's Avatar
you can call adams and they will cut your stock pan and put a pick in it for 150.00.....
gbillzx10r is offline
