Rounded Off Bolt - Kawasaki ZX-10R.net
post #1 of 27 Old 02-18-2008, 06:49 PM Thread Starter
JaydeeZX10's Avatar
Images: 7
Send a message via AIM to JaydeeZX10 Send a message via Yahoo to JaydeeZX10
Rounded Off Bolt
Guys Im taking my wheels off to get them powdercoated for some reason two of the bolts that hold the front rotor on rounded while trying to remove them with the allen key. the last one came out ok just these two. Any sugestions on how I should get them out? Thanks in advance.
JaydeeZX10 is offline
post #2 of 27 Old 02-18-2008, 06:55 PM
konichd's Avatar
Use an "easy out" bit or you could use a dremel and cut slots for a flathead screwdriver and get it out with a drill. I had the exact same thing happen. I used and "easy out" and it came out luckily. Good luck, those bolts are soft and with Red loctitie their easy to strip.
konichd is offline
post #3 of 27 Old 02-18-2008, 07:03 PM
stadanco's Avatar
Easy out is the way to go just make sure to use right size drill bit and get a good bite before you go for it. As your turning the easy out tap it with a hammer to keep it biting.
Never had much luck with the flat head aproach and its easy to slip and dick up surrounding parts while doing it, def last resort
stadanco is offline
post #4 of 27 Old 02-18-2008, 07:04 PM
Big Daddy's Avatar
Images: 38
exactly. fuggen red loctite with soft bolts is a nightmare.
Big Daddy is offline
post #5 of 27 Old 02-18-2008, 07:08 PM
MIA Ex-Mod
Tread70's Avatar
Prior to removing rotor bolt use an allen socket of the right size and before you put a ratchet on it take a deadblow hammer and give them a good whack or 2 with the socket in the bolt head to loosen up the locktite. They may still come out with an allen socket after whacking them a couple of times to help loosen up the locktite, depending on how bad they are rounded. Worth a try.....
Tread
Tread70 is offline
post #6 of 27 Old 02-18-2008, 07:21 PM
stadanco's Avatar
Speaking of hammering it in the star sockets, security bits like the ones on your ignition will bite sometimes to when things get ugly.
stadanco is offline
post #7 of 27 Old 02-18-2008, 07:24 PM
nczx-10r's Avatar
Tread
:+1
nczx-10r is offline
post #8 of 27 Old 02-18-2008, 07:30 PM
rocketracermike's Avatar
Those bolts are a nightmare. I used a easy out.
rocketracermike is offline
post #9 of 27 Old 02-18-2008, 07:31 PM
Daves Cycles's Avatar
Use a impact driver with the correct size allen.Put coarse valve grinding compound on the tip on the allen(the sand in the compound helps bind the allen)Now hit the impact driver with a very solid hit and turn(solid hit helps break up the loctight).
If that doesn't do it,nothing else is easy.Easy out or drill the head of the allen off then use vise grips on the stud.
Daves Cycles is offline
post #10 of 27 Old 02-18-2008, 07:31 PM
kawiiiiii's Avatar
Images: 19
I had the same problem with one of those bolts. I tick welded a alen key to the bolt and took it out.
kawiiiiii is offline
PC for bolt on, af and pc jezzolo Vendor Deals 1 04-19-2007 05:00 PM
Pro-bolt kit blue thunder Performance and Tech 27 03-20-2007 09:13 PM
Bolt on jlmac90 The ZX-10R 10 12-14-2005 07:07 PM
Looking for a bolt on Older Guy The ZX-10R 11 10-20-2004 06:31 PM
