rotors - Kawasaki ZX-10R.net
post #1 of 5 Old 01-25-2011, 12:56 PM Thread Starter
Btrain87's Avatar
rotors
i have decided i want to change the rotors on my gen1 04 10r. i did a search on rotors and i know that more surface area is good and more holes keep them cool. other than that, what else am i looking for? basically i want to know, what makes brembo the best? how does galfer compare and are the rotors useless if i use the oem calipers? thanks everyone in advance!
Btrain87 is offline
post #2 of 5 Old 01-25-2011, 02:03 PM
Strik33r's Avatar
to get more surface area, you would also need bigger pads, calipers etc..
you wont notice a big change with rotors, switch the calipers.. that is the problem on the 1st gen, calipers, lines and master cylinder....
Strik33r is offline
post #3 of 5 Old 01-25-2011, 02:07 PM
Licensed Dist of HaterAde
TMY10ER's Avatar
most aftermarket rotors will be semi or full floating rotors and are made from better material to dissipate heat faster n such. shop around and you'll find that rotors from alth,brembo,ebc,galfer,braking,ferado, etc are all alot similar but then again it boils down to what you've done to the rest of your braking system IMO anyway, you running the stock master cylinder,lines,calipers,pads? i've seen several nice new sets around and will send you some links if you'd like? we run 300mm rotors but if you find a set from several years of the ZX6-Zx6r they are compatible. let me know and i will gladldy pm or email you quite a few links i've saved on the rotors. there are also several other factors which will make one brand of rotor more expensive or "better" than others. i had a set of brembo hp rotors but got rid of them and ended up getting a set of the alth rotors BUT would love to get a set of ebc prolites.
TMY10ER is offline
post #4 of 5 Old 01-25-2011, 02:10 PM
TMY10ER's Avatar
:headshake...not soo much man, the problem on the 1st gen is the master cylinder...kawi chose to run a standard MC with radial calipers... if you simply just switch the MC over to a radial unit then you'll notice a HUGE difference...this is even using stock lines and pads.....swap out the MC,lines,pads,and maybe throw some rotors on and you'll be amazed!!! even without the rotors simply doing the MC swap is a VERY noticeable improvement!!
TMY10ER is offline
post #5 of 5 Old 01-25-2011, 02:14 PM
TinMan_38's Avatar
quality of materials and manufacturing is the key. good rotors will work fine with stock calipers, just use good quality performance pads. I agree that the weak point is the master cylinder. upgrade to a 2nd gen mc, or better yet go with the brembo radial. itll be like night and day. stainless hoses are a must as well.
TinMan_38 is offline
07/08 ZX-6R rotors compared to 08 ZX-10R rotors nickalltogether The ZX-10R 7 08-06-2009 07:20 PM
zx9 rotors tank zx10r Wanted: Buy or Trade 0 07-03-2008 10:45 PM
FS- ZX-14 Rotors ILOAD2 Parts, Gear and Accessories 1 07-01-2008 07:36 PM
04-05 front rim with rotors & rotors WSMC712 Wanted: Buy or Trade 1 08-17-2006 12:14 PM
Anybody know or seen these rotors for the 10? 1killer1liter Performance and Tech 14 03-07-2006 01:17 PM
