reworking the crashed brembo MC ***pics - Kawasaki ZX-10R.net
post #1 of 11 Old 10-23-2007, 10:13 AM Thread Starter
plasticbaby's Avatar
i have repaired my crashed brembo MC this afternoon,i take a few photos,and i hope it would help other guy who is first reworking their brembo mc.
the first thing is to get the lever off,JimmyJam have a great instruction how to do it(thank you JimmyJam)
"To do this you have to drive out a very small diameter roll pin. I use a very small finsihing nail. Then remove the e-clip and the pivot pin will drop out. You can then rotate the lever and it will spin off the part you are going to replace in the crash repair kit."
and then,you need a special tools to get that rubber hat off,but please remember there are some sealant on the screw,and it seems a little difficult to me.
and i don't have that special tools,you can see the result is not so good.
ID:	48048   Click image for larger version
plasticbaby is offline
post #2 of 11 Old 10-23-2007, 10:17 AM Thread Starter
then,you can get the push rod totally off,and see the broken aluminum hat
ID:	48051   Click image for larger version
post #3 of 11 Old 10-23-2007, 10:25 AM Thread Starter
in fact,i did not buy the brembo mc crash repair kit yet,so i decided to make one.
the original hat was broken,so it's hard to measure in some place,although the new hat is not exactly the same size as the brembo made,but i think it would work perfectly still.
ID:	48057   Click image for larger version
ID:	48058   Click image for larger version
ID:	48059   Click image for larger version
post #4 of 11 Old 10-23-2007, 10:29 AM Thread Starter
all the parts need re-assemble now
ID:	48061   Click image for larger version
post #5 of 11 Old 10-23-2007, 10:36 AM Thread Starter
here is a little tip,when you push the piston into the cylinder,you'd better use a tool which have the smooth surface to help the top rubber seal into the cylinder.be carefule don't scratch that rubber seal,or you brembo mc will get leakage maybe.
i use chopsticks:)
post #6 of 11 Old 10-23-2007, 10:41 AM Thread Starter
the job is done,i have not tested yet,but i think this brake system should work like before.
ID:	48064   Click image for larger version
post #7 of 11 Old 10-23-2007, 12:29 PM
edouble's Avatar
Excellent thanks for the info!!
edouble is offline
post #8 of 11 Old 10-23-2007, 02:53 PM
jdgun_13's Avatar
Send a message via Yahoo to jdgun_13
shit i need to do this being my lever just doesnt have the initial bite like it did and will bottom out under extreme lever pressure.
failed tech inspection because of that rascal.
Will try this out.
Thanks in Advance
jdgun_13 is offline
post #9 of 11 Old 10-23-2007, 03:41 PM
luckz88's Avatar
Send a message via AIM to luckz88 Send a message via Yahoo to luckz88
nice
luckz88 is offline
post #10 of 11 Old 10-23-2007, 09:54 PM
That's not to come out. That's why there is glue on it. The rubber gasket (boot) comes off then you take the c-clip off
Lvninja is offline
Reworking the OEM fork vs. Ohlins R&T Rspec99 Performance and Tech 68 02-14-2011 06:15 PM
Reworking the OEM fork vs. Ohlins R&T Rspec99 How To... 2 06-25-2007 12:32 PM
almost crashed ! performancezx10r The ZX-10R 22 04-20-2005 08:33 AM
Not mine, but a crashed black 10... Pics>> El Diablo Pictures and Videos 5 11-02-2004 02:15 PM
Crashed my 10R Afterburner The ZX-10R 20 06-11-2004 11:52 AM
