Revisiting the T.R.E. - Kawasaki ZX-10R.net
post #1 of 27 Old 04-01-2006, 05:52 PM Thread Starter
sosmc1's Avatar
I stopped using my TRE months ago because I could never get it to function w/o causing an amazingly large dead spot at under 3500 RPM. I have Ivan's map and have tryed all, but a custom one. I want to try it again. Any suggestions???
If I can't ride it or it can't make me a sandwich, I don't want to be bothered!!!
sosmc1 is offline
post #2 of 27 Old 04-01-2006, 10:22 PM
10 speed's Avatar
I live by the beach and kws told me the ivans map wont work due to the air being different here. uhhh im not sue how to upload maps but i will try. ugg couldnt do it...
I got tiered of buying go fast parts.... So i got a turbo! now i need go slow parts!
If it aint modded it aint yours!
10 speed is offline
post #3 of 27 Old 04-02-2006, 12:15 AM
CanyonCarver is offline
post #4 of 27 Old 04-02-2006, 04:46 AM Thread Starter
sosmc1's Avatar
The air is different?? Hows that?? Are u sure they weren't talking about temp. and climate? Do you have a map that works? If so can I get a copy of the file?
sosmc1 is offline
post #5 of 27 Old 04-02-2006, 06:56 AM
If you want it to run it's best, you'll need a custom map for your bike. Not one from another bike. Also, did you rotate the sub-throttle sensor? If not, you will have a dead-zone at lower rpms. If you aren't willing to get a custom map made for your bike, I suggest you leave the TRE off.
post #6 of 27 Old 04-02-2006, 07:03 AM Thread Starter
sosmc1's Avatar
I did rotate the sub throttle sensor, but no go. I have not had the best luck with custom maps over the years, but maybe one more try.
sosmc1 is offline
post #7 of 27 Old 04-02-2006, 07:17 AM
Your sig says you're in SoCal. Take it to Louis at L&L Motorsports. He has a dyno in a trailer and knows his shit. He can usually be found on any race day at Willow Springs, but you should give him a call to confirm. Does many of the local racers' bikes. Did mine, too. You won't be disappointed.
post #8 of 27 Old 04-02-2006, 07:24 AM Thread Starter
sosmc1's Avatar
thanx i'll do that. Do you know his usual rates?
sosmc1 is offline
post #9 of 27 Old 04-02-2006, 07:41 AM
10 speed's Avatar
I live by the beach witch = lower air pressure. and DO NOT rotate the subthrotle position sensor. this will cause throtlebody problems. throtlebodies are $1200 I have dyno charts to prove 173 rwhp trust me i know what im talking about. yes i have a map but i dont know how to post it. everytime i try it trys to post the whole pc3 program..
10 speed is offline
post #10 of 27 Old 04-02-2006, 08:07 AM Thread Starter
sosmc1's Avatar
You have to go into your file and copy the map byitself then post it. Thanx
sosmc1 is offline
T.R.E. Mod? silvermonster Performance and Tech 19 03-24-2006 01:30 AM
Arata full ex. map with BMC filter and T.R.E. Amish_Ninja Performance and Tech 7 11-23-2005 11:19 PM
T.R.E. mod..... R1GSXRKILLER The ZX-10R 14 02-10-2005 01:07 PM
