Reversing wire mod? - Kawasaki ZX-10R.net
post #1 of 6 Old 07-31-2014, 11:36 AM Thread Starter
Reversing wire mod?
Ok so ive looked around and can't find anything that answers this question. When Im trying to reconnect the red/greens wires they dont touch, so what im wondering is if its ok to just use a cap to connect them or would that act as a resistor or something? So yeah just trying to see if they will be fine capping and using electrical tape.
Thanks, Paul
ambitionzcs is offline
post #2 of 6 Old 07-31-2014, 11:40 AM Thread Starter
Oh and ive never used solder for electrical and Don't have the equipment for it atm.
post #3 of 6 Old 07-31-2014, 11:40 AM
dricked's Avatar
Just solder in a new piece of wire that will connect the two. Cut the wire back a little further on the harness side to give you some room to make it tidy.
You can buy what you need for under $20. You'll use it again and it's easy to do. I'm sure if you use google you'll find some directions.
dricked is offline
post #4 of 6 Old 07-31-2014, 01:36 PM Thread Starter
Thanks I ended up buying the kit and doing it right, i appreciate the input.
post #5 of 6 Old 07-31-2014, 02:05 PM
X2 to what Drick said.
Be sure to clean the solder connections with isopropyl alcohol, heat shrink it then electrical tape it. You want it to be as near air tight as possible. Moisture can find its way in there through humidity, condensation, rain, etc. If it does over time it will start to oxidize the copper and basically rot out your wiring and you'll be looking at a more in depth (and expensive) repair. Do it right; spend the the extra couple of bucks on heat shrink and take the extra 10 minutes to properly finish the job. Those 10 minutes and $4 now can be the difference between enjoying your machine or enjoying downtime and potentially expensive repair.
ZX10RArcher is offline
post #6 of 6 Old 08-03-2014, 12:12 PM
Wrangoleer's Avatar
When I did mine I installed butt connectors on both ends so that it would be easy to undo.
Wrangoleer is offline
Gen 4: Wire Mod Comparison ZX10RArcher The ZX-10R 19 05-20-2014 12:28 PM
Gen 4: Wire mod Antwann08 The ZX-10R 71 01-11-2014 06:43 PM
Wire mod help stanmart General Motorcycle Discussions 5 06-28-2013 09:14 AM
Wire mod done. :( URBAN LEGEND The Out House 14 12-25-2012 10:34 AM
how do I do the wire mod? zx-twitch ZX-6R & ZX-6RR Archives 1 02-27-2009 08:35 AM
