Reverse Shifting - GP Style - Kawasaki ZX-10R.net
post #1 of 36 Old 04-01-2008, 11:29 AM Thread Starter
edouble's Avatar
First off - I know there are a lot if threads about this topic so donít hammer me about using the search feature; I did!
With stock rearsets and standard shift pattern, the clamp going into the transmission was in the 12 o'clock position, with the bike in neutral. I installed Vortex rearsets and also wanted to change to the reverse shift pattern. I flipped the clamp going to the transmission to the 6 o'clock position (bike in neutral), which from what I have read will reverse the shift pattern. I also notched the lower faring with a dremel tool. I have to lift on the shift pedal to get the bike in first, the way it should be with this setup. When I press down on the shift linkage the transmission does not want to go into second. If it does shift at all it goes into neutral or third. Anybody know what I am doing wrong?
FYI: Unfortunately it is raining outside and I am not taking my bike out. I "rocked" the bike back and forth to get it to shift and I am experiencing a problem.
edouble is offline
post #2 of 36 Old 04-01-2008, 11:54 AM
FAF
Rent this space
The shift rod should be at 90 degrees to the small lever so you have the same movement to and fro.
Try moving the lever a couple of splines anti clockwise.
FAF is offline
post #3 of 36 Old 04-01-2008, 11:55 AM
luckz88's Avatar
Send a message via AIM to luckz88 Send a message via Yahoo to luckz88
Do a search, lol just kidding
try what he said above...you have it close to working
luckz88 is offline
post #4 of 36 Old 04-01-2008, 12:10 PM
jleachma's Avatar
i know you said it will go to third; not sure on other gens, but on the 08 you cant go into second while sitting still. it goes straight to neutral. maybe try it going slow down your street
jleachma is offline
post #5 of 36 Old 04-01-2008, 12:27 PM
SkyDork's Avatar
All Kawasaki sportbikes manufactured since the late '80s have a Positive Neutral Finder (PNF) that will not allow the xmission to engage the higher gears (2nd thru 5th) unless the tranny is moving. If you're attempting to do this with the bike stopped, it should not be possible. From the pics, you did the conversion OK and there's nothing there alone that would cause this problem to happen.
#WordCrimes
SkyDork is offline
post #6 of 36 Old 04-01-2008, 12:30 PM Thread Starter
edouble's Avatar
That makes a lot of sense, thanks to everyone for their input! I will not be able to take the bike out for a few days. I will post what's up then.
edouble is offline
post #7 of 36 Old 04-01-2008, 12:39 PM
erikspeed's Avatar
I am in same configuration of you and I do not have any trouble as you said!
Was it working well in normal shifting?
because your problem is abnormal??? Unless the gear box is touched??? do you stunt?
erikspeed is offline
post #8 of 36 Old 04-01-2008, 12:45 PM Thread Starter
edouble's Avatar
bike always shifted fine, no I dont stunt
edouble is offline
post #9 of 36 Old 04-01-2008, 12:55 PM
erikspeed's Avatar
once you have put in reverse shifting the problem came out right?
post #10 of 36 Old 04-01-2008, 01:00 PM
7774me's Avatar
SORRY OFF TOPIC!!
EDOUBLE - I have the same racerailz and am about to install. Throw up a couple pics/advice of them babies would ya!!
7774me is offline
Std vs. Reverse Shifting afskypilot Performance and Tech 16 12-28-2007 07:49 AM
Reverse Wheelie! mjg68901 Pictures and Videos 25 02-25-2007 09:26 PM
Reverse GP Shifting RickRoush03 The ZX-10R 3 05-12-2005 05:53 PM
MotoGP or reverse shifting Older Guy The ZX-10R 11 03-30-2005 12:19 PM
How many of us are GP (reverse) shiftin'? El Diablo Performance and Tech 59 12-23-2004 08:14 PM
