Reverse shift Rear sets/zx10r 2005 - Kawasaki ZX-10R.net
post #1 of 10 Old 10-27-2008, 01:07 PM Thread Starter
orecha28's Avatar
Images: 7
Question Reverse shift Rear sets/zx10r 2005
Does any of u guys know how to reverse shift with the stock rear sets, or wich rear sets would be the best to buy for this pourpose.???????? thanx in advance
orecha28 is offline
post #2 of 10 Old 10-27-2008, 01:18 PM
Ex Postwhore
9520G's Avatar
Send a message via MSN to 9520G
I think most of the aftermarket rear sets give you the option. I know the sato ones do.
"Never trade the thrill of living, for the security of existence"
9520G is offline
post #3 of 10 Old 10-27-2008, 01:40 PM
I have done it on my stock ones, very simple. See where the rod clamps to the transmission? Just take out that screw and take the clamp off, turn it 180 degrees from what it was, put it back on, put the screw back in and vuala... you've got backwards shifting 1 up 5 down. You may need to cut a notch in your lower fairing to allow for movement of the shift rod, but only about the size of a nickel.
maineiac1008 is offline
post #4 of 10 Old 10-27-2008, 01:46 PM
Postwhore with an 04
bcm0018's Avatar
I have satos but I don't see why you couldn't reverse the stock rear sets. Only potential problem would be the height of the shifter if you can't adjust the height.
Just do what maineiac said. I had to notch my fairing too but its no big deal. I used a dremel tool.
bcm0018 is offline
post #5 of 10 Old 11-02-2008, 08:03 AM
Originally Posted by maineiac1008 View Post
i have done it on my stock ones, very simple. See where the rod clamps to the transmission? Just take out that screw and take the clamp off, turn it 180 degrees from what it was, put it back on, put the screw back in and vuala... You've got backwards shifting 1 up 5 down. You may need to cut a notch in your lower fairing to allow for movement of the shift rod, but only about the size of a nickel.
+1
TheDon is offline
post #6 of 10 Old 11-02-2008, 08:09 AM
rkwaki's Avatar
When you unbolt the shifter at the tranny just make sure you hold the lever itself so that it is positioned in the same spot.
If you have nothing nice to say - "Shut the [email protected] up"
rkwaki is offline
post #7 of 10 Old 11-02-2008, 08:09 AM
GEN II Driver
ripper's Avatar
reverse shifting is kind of a pain in the arse unless you're into it or need the clearance in left turns to upshift. .02
MDCCLXXV
ripper is offline
post #8 of 10 Old 11-05-2008, 04:13 PM
Post Whore
manieiac hit the nail in the head
Nick.INF is offline
post #9 of 10 Old 11-05-2008, 05:37 PM
1g-10r's Avatar
I did this on my bike for quicker shifts while drag racing.
1g-10r is offline
post #10 of 10 Old 11-05-2008, 07:45 PM
Originally Posted by thedon View Post
+1
10 min. tops
10man04 is offline
Reverse Shift - How To...??? bgruhn76 Performance and Tech 23 06-18-2014 12:48 PM
Reverse shift on 08?? SPEEDFREAKZX10R The ZX-10R 10 04-30-2008 09:58 PM
Reverse shift pattern jasonmayer General Motorcycle Discussions 2 03-02-2008 08:55 PM
Reverse Shift Pattern Salesguy10r The ZX-10R 17 03-10-2006 01:32 PM
reverse shift pattern along Performance and Tech 20 11-08-2005 10:29 PM
