Reusable Cotter Pins - Kawasaki ZX-10R.net
post #1 of 9 Old 06-05-2016, 12:58 PM Thread Starter
Does anyone know where I can source this part to fit through the axle and nut of the Gen 4 rear axle?
BOP Leader is offline
post #2 of 9 Old 06-05-2016, 01:07 PM
Lowes
Home Depot
2011 ZX10R
2012 FZ6R
2012 TU250X
2013 ZX6R
2017 GSX-R1000R
realpsi is offline
post #3 of 9 Old 06-05-2016, 03:40 PM
You can get a split lock washer to replace the oem washer and ditch the cotter pin.
obijack is offline
post #4 of 9 Old 06-05-2016, 03:45 PM
or10r's Avatar
or10r is offline
post #5 of 9 Old 06-05-2016, 04:01 PM Thread Starter
Originally Posted by or10r View Post
Medium looks perfect. Thank you Sir.
post #6 of 9 Old 06-06-2016, 03:30 AM
or10r's Avatar
You betcha man. Always glad to help...IF I actually can.
or10r is offline
post #7 of 9 Old 06-07-2016, 09:37 AM
KIXASS's Avatar
I use this hitch pin which can be found at Home Depot, Lowes and Tractor Supply.
KIXASS is offline
post #8 of 9 Old 06-08-2016, 01:15 PM
57x
The problem with these clips is they are easy to catch on things and spring open. I lost one of those clips off a bike and had no idea how long I went without it. The R clip @obijack mentioned is a better solution for an axle lock. Mostly what I use.
57x is offline
post #9 of 9 Old 06-13-2016, 06:38 AM
I use rear axle sliders. Woodcraft (a highly respected and reputable company) sends a 24mm split lock washer with their kit (i used the evotech kit which did not include a split lock washer). The washer allows you to get rid of the cotter pin all together, because it keeps tension on the nut. I have been doing a lot of very hard riding since i changed from he cotter pin to the split lock washer. I have checked the torque of my axle nut many times. The nut's torque has not changed, at all. I bought my split lock washer from Ace.
https://www.fastenal.com/products/de...L6420000A40000
obijack is offline
Gen 4: Pitbull Restraint Pins rogue Wanted: Buy or Trade 0 07-18-2014 10:00 PM
Axle cotter pin question. Wrangoleer Performance and Tech 25 06-17-2014 07:10 AM
reusable oilfilter caprice Performance and Tech 22 12-16-2012 01:26 PM
cotter pins alanxrhrc The ZX-10R 22 04-19-2011 01:30 PM
PC racing reusable oil filters HOOCH The ZX-10R 62 02-02-2010 10:39 PM
