Gen 2: 2006-2007 Replacing ECM questions - Kawasaki ZX-10R.net
post #1 of 2 Old 11-07-2019, 04:06 PM Thread Starter
KEValenta's Avatar
So my gen 2 ZX10R is only running on cylinders 2 & 4. I’ve tried switch 1 & 3 coils to 2 & 4 with no change. Did the same thing with spark plugs, same result. Getting power to all coils & injectors. Someone else on the forum had this same issue and remedied it with a new ECM(second hand). So a used ECM will be arriving next week. Will the new ECM just plug in with no issues or will I need to reprogram the ignition to the new ECM? Any advice would be greatly appreciated.
KEValenta is offline
post #2 of 2 Old 11-07-2019, 06:44 PM
Kawasaki Brad's Avatar
Plugs in with no issues.
Disconnect your battery until you're done plugging and unplugging stuff.
Kawasaki Brad is offline
