removing wheel bearings??? - Kawasaki ZX-10R.net
post #1 of 3 Old 04-18-2006, 02:56 PM Thread Starter
I am removing my wheel bearings to replace them with ceramic...what tool or size sprockets do I need to get them out??? Never messed with bearings before so all help is needed...
Thanks
on1whl is offline
post #2 of 3 Old 04-18-2006, 03:16 PM
Big Daddy's Avatar
Images: 38
If your dead set on removing them yourself you'll need a hammer, 12-15" drift or punch with a flat nose on the buisness end thats capable of going all the way through the center spacer and reach the opposite bearing.
A heat gun is a plus if available but not a must but when you begin the process with the drift inside you'll need to move the inner spacer on the opposite end to one side so that your able to gain access to the inner race of the bearing and once you do place the flat surface of the drift onto the race and begin tapping / striking it (yes its caveman like) and work your way around the race so that the bearing begins to exit straight and not crooked and as you work it you'll begin to feel it move outward until it pops out completely. Once the 1st one is done you can use a suitable sized socket W/extension the size of the inner race on the opposite one until it pops out.
Side note: be carefull how you treat the inner spacer as its aluminum and damages easily.
Big Daddy is offline
post #3 of 3 Old 04-18-2006, 03:23 PM
Ruthless Racing's Avatar
Images: 9
and be careful installing those expensive ceramic bearings. Good Luck.
Kenny Poppell
AMA Dragbike SuperSport #1000
2007 AMA Dragbike 1000SS National Champion
2007 1000SS 1/8th ET Record Holder 5.967
Best 1/[email protected] Best 1/[email protected] Stock Wheelbase
Special Thanks:
Performance Psycle
Richies Tires
http://www.XXXRacingFuel.com
http://www.SuperbikeSpecialties.com
http://www.Tsukigi.com
http://www.CycleConceptsRacing.com
http://www.myspace.com/ruthlessracing1
Ruthless Racing is offline
wheel bearings 04ZX10 The ZX-10R 23 05-22-2009 11:38 AM
counter sprocket and wheel bearings 04ZX10 Performance and Tech 6 03-22-2006 01:32 PM
Wheel Bearings Problems? zixxer The ZX-10R 19 06-06-2005 03:08 PM
Wheel bearings 1killer1liter Performance and Tech 4 04-28-2005 05:47 PM
Warning About BST Carbon Fiber Wheels........ SP8 The ZX-10R 20 01-18-2005 08:28 AM
