removing stock headlight assembly? - Kawasaki ZX-10R.net
post #1 of 3 Old 10-03-2005, 10:40 PM Thread Starter
ghostrank's Avatar
hi gang i have a headlight bulb that got smashed inside my headlight assembly as i was trying to replace it with a silverstar bulb... well anyways i need to remove the entire headlight assembly to clean it out of all the bulb scraps. is taking off the headlight assembly easy to do?
hmm maybe i can blow compressed air in the assembley to blow it out!? :)
thanks!
S.
ghostrank is offline
post #2 of 3 Old 10-03-2005, 10:48 PM
Ruthless Racing's Avatar
Images: 9
thanks!
S.
The only thing that holds the front on is the 4 ram air tube bolts and the bolts on the side plastic, and some wire terminals. You might could try a high power vacuum cleaner.
Kenny Poppell
AMA Dragbike SuperSport #1000
2007 AMA Dragbike 1000SS National Champion
2007 1000SS 1/8th ET Record Holder 5.967
Best 1/[email protected] Best 1/[email protected] Stock Wheelbase
Special Thanks:
Performance Psycle
Richies Tires
http://www.XXXRacingFuel.com
http://www.SuperbikeSpecialties.com
http://www.Tsukigi.com
http://www.CycleConceptsRacing.com
http://www.myspace.com/ruthlessracing1
Ruthless Racing is offline
post #3 of 3 Old 10-04-2005, 08:44 AM
sneaky's Avatar
I would be extremely careful of what you do, the reflector assembly is very easy to scratch. A high powered vacum could cause the fragments to scratch the reflector as they are sucked by the vacuum.
sneaky is offline
Clear Alternatives Integrated Light How-to... El Diablo The ZX-10R 37 04-06-2010 10:41 PM
Clear Alternatives Integrated Light How-to... El Diablo How To... 1 02-25-2005 10:24 AM
WTB Stock parts '04ZX10R BackMarker Wanted: Buy or Trade 9 11-03-2004 09:51 PM
